Author Topic: Replacing resistor help  (Read 1221 times)
rfr341
  • Last login:May 24, 2017, 12:15:31 am
« on: August 29, 2009, 11:58:25 am »
I have to replace a 330 ohm 30 watt ceramic cement wire wound resistor on my mtc 9000 and I can't find a replacement resistor of that size an make, there doesn't seem to be anyone selling ceramic cement wire wound resistors with that high wattage. My question is can I replace the ceramic cement resistor with an aluminum covered wire wound resistor? I have found one that is 330 ohm 50 watt.
Ed_McCarron
Re: Replacing resistor help
« Reply #1 on: August 29, 2009, 02:26:55 pm »
As long as the additional impedance created by the wire coil isn't an issue (is the resistor seeing DC or AC?  Frequency?) the higher wattage resistor should work fine.
