Author Topic: DWJuke question  (Read 7218 times)
durandal_666
  • Last login:April 29, 2011, 04:46:46 am
    • The Project
DWJuke question
« on: August 29, 2009, 08:57:47 am »
Got a question about DWJuke.  Currently set it up on my WIP cab as a joystick operated jukebox  - i know its not written for that in mind but Im much happier with DWJuke than other jukeboxes (Im running a micro-atx, so its low powered.  DWJuke has just enough bling without making my CPU cry).
Playstimulator & radio mode.  I had playstimulator set to the same time as my screensaver, so when left unattended the screensaver kicks in and it plays random music.  Great for parties when you cant get to the cab for whatever reason (READ: Too much booze).  However the playstimulator (like a real jukebox) plays a song and resets the counter, which leaves a lull.  I tried radio mode, but radio mode starts playing as soon as the juke is loaded.
I would like to run it so that it drops into radio mode after xx seconds of non play.  Ive tried fiddling with the settings in both skin and jukebox.ini to no avail.
Is this possible with current settings?  I can easily bind BTN_RADIO to a button on the cab but its just not quite as polished as dropping in automatically after a specified idle time.
Foldup Portable MAME case project: http://durandal666.blogspot.com
Chris
    • Chris's MAME Cabinet
Re: DWJuke question
« Reply #1 on: November 01, 2009, 11:36:37 pm »
I apologize for the lack of answer to this question.  There is no way to do this with the current version of the jukebox.
There is a feature I just added tonight that may work for you, though, and that is user timers.  So you'd want the juke to go into radio mode after it's been idle for a time; that part is easy.  The question is when do you want radio mode to stop?  Once radio mode starts, of course, the jukebox is no longer idle...
So let's solve the first problem: How to trigger radio mode?  The timer would look like this:
[Timer1]
#Intervals are measured in hundredths of a second
# 30000 = 5 minute interval
Interval=30000
# Autostart defines whether the timer starts when the jukebox starts
AutoStart=No
# Repeat determines whether the timer automatically repeats, or repeats a set number of times
Repeat=No
# StartAction and StopAction are messages that will stop and start the timer
StartAction = MSG_IDLE
StopAction = -MSG_IDLE
# OnStart, OnRepeat, OnEnd and OnStop are the messages that are sent at the beginning and end of a timer run.
# OnStart triggers as soon as the timer is first started.  Will probably never be used.
# OnRepeat triggers when the timer reaches the end of its timer and restarts
# OnEnd triggers when the timer reaches the end of its timer and does not restart.
# OnStop triggers when the timer is stopped by its stop message.  Will probably never be used.
OnEnd=CMD_RADIO
So this would start a one-time timer when the jukebox goes idle.  If it goes the full 5 minutes, it will toggle radio mode (and radio mode must be off already if the jukebox is idle at all).  If the tyimer endfs because hte juke is no longer idle, it will not trigger radio mode.
So how do we STOP radio mode?  If we trigger off MSG_SELECTING, then radio mode would be cancelled as soon as anyone enters any selection digits or letters.  However, CMD_RADIO toggles the radio state, so radio mode will keep going on and off.  I need to add discrete commands such as CMD_RADIO_ON and CMD_RADIO_OFF to guarantee a particular state gets set; that is easy enough.  So assuming that is done, the second timer looks like this:
[Timer2]
#0 indicates that the timer will go off immediately
Interval=0
AutoStart=No
Repeat=No
StartAction = MSG_SELECTING
OnEnd=CMD_RADIO_OFF
So there we have it.. with the addition of these new timers you would have a radio mode that goes on after 5 minutes of idle and goes off as soon as someone manually selects a song.
There is one catch... MSG_SELECTING isn't triggered if a song is clicked on directly.  I'll have to do something about thaat.
--Chris
--Chris
Kevin Mullins
    • Me on Myspace
Re: DWJuke question
« Reply #2 on: November 03, 2009, 12:46:26 am »
Very cool Chris.....  :cheers:
I may have to actually install a newer version of DWJuke now into my jukebox.
Chris
Re: DWJuke question
« Reply #3 on: November 03, 2009, 01:01:34 am »
I am trying to finalize it for a release over the next few days.
--Chris
