Author Topic: Dreamcast Controller ports dead  (Read 3877 times)
david656
  • Last login:June 01, 2017, 10:06:24 am
  • Big Man!
« on: August 28, 2009, 10:01:42 am »
I don't currently have a replacement pico fuse but am under the understanding that's what is the problem, is there a temporary fix i can try to see if that is the problem?
cheers
  • Last login:Yesterday at 10:26:35 am
Re: Dreamcast Controller ports dead
« Reply #1 on: August 28, 2009, 10:09:21 am »
Yes, you can solder a resistor in its place.  Let me look up the value...
« Reply #2 on: August 28, 2009, 10:10:43 am »
5 ohm
david656
  • Big Man!
« Reply #3 on: September 01, 2009, 02:54:07 pm »
Update,
Haven't tried the 5ohm resistor but about to  :) BUT i've ordered 10 of these http://uk.farnell.com/multicomp/mcpfp-0-5a-125v/fuse-axial-quick-blow-0-5a/dp/1566026 which came today, and i soldered it on and.. well its still not working.. BUT my spare controller board works fine, so i can only assume that that is the wrong fuse, or possibly that something else got blown?
any advice greatly received
« Reply #4 on: September 01, 2009, 03:01:42 pm »
Probably the wrong fuse.     That is the wrong item.
You need a 5 ohm fusible resistor, but in a pinch, a 5 ohm carbon type resistor will do.
« Last Edit: September 01, 2009, 03:03:45 pm by HarumaN »
david656
  • Big Man!
« Reply #5 on: September 01, 2009, 03:31:49 pm »
well
for a start http://www.mmmonkey.co.uk/console/sega/dc-reset.htm#update is wrong.. the R1 that looks like a resistor is ... a resistor ! and F1 is... a fuse ! so i switched them round and the bored now works.. with the original resistor and the new fuse.. the old fuse was definitely dead when checked with multimeter.
What risks am i taking by using the fuse i bought and have fitted ?
edit: would maplin's stock the fusible resistor?
Nipedley
  • Last login:October 04, 2024, 12:03:26 am
« Reply #6 on: September 02, 2009, 06:43:12 am »
Well the fuse you are using is only 500mA compared to the 390mA he states, I wouldn't worry about that at all. Glad you managed to get it working again :)
