Author Topic: Rolpa's Mame Cabinet Conversion  (Read 2412 times)
Rolpa
  • Last login:August 16, 2021, 09:52:07 am
« on: August 28, 2009, 01:51:26 am »
Hello everybody. I have been dieing to have an arcade cabinet since I was a little kid. So I decided to convert an old cabinet into a Mame box. After a lot of searching around, I finally found a cabinet to convert:
Judging from the curved marque,  I think this was originally a RoboCop cabinet. However, It was converted into a Marvel Vs. Capcom machine, and finally had that taken out of it, so I think it's safe to convert it to a Mame cab.
This is going to be my first build, and I have decided to keep the control setup the way it is, although I might switch out the joysticks with Ultimarc sticks, since those can be switched from four-way to eight way from the top of the control panel. I also have to replace the player one start button with an actual player 1 button. On top of all of that, both the t-molding and coin door are missing, so I'll have to get new ones.
Needless to say, this will take a lot of effort, but it should be fun.
Beretta
Re: Rolpa's Mame Cabinet Conversion
« Reply #1 on: August 28, 2009, 04:59:06 am »
ah ya, the curved marquee is pretty unique.. i remember bad dudes also had a curved marquee so might also be that, both dataeast games.
severdhed
  • RIP Dinosaur Hippo
« Reply #2 on: August 28, 2009, 02:33:59 pm »
looks like a great start for a good project.  It will take some work, but that is the fun part.  good luck and make sure you take lots of pics.
saleem
  • Last login:February 07, 2012, 08:03:39 am
« Reply #3 on: August 28, 2009, 02:39:21 pm »
and its expensive!
 :P
