Author Topic: Mame full gamelist for hyperspin xml help needed  (Read 7497 times)
abispac
  • Last login:March 01, 2026, 10:21:07 pm
« on: August 27, 2009, 10:31:44 pm »
I created a xml mame gamelist for hyperspin with romlister, it came out with a few errors but i cleaned up, but still does not work with hyperspin, i eve cheked the xml file with a xml software, and comes out ok , can someone take a look at it and tell me whats wron with it, thanks.
http://rapidshare.com/files/272405203/mame.xml
« Last Edit: August 27, 2009, 10:33:42 pm by abispac »
NOP
  • Last login:September 19, 2017, 08:22:27 pm
  • I stole my avatar.
    • winterMAME
Re: Mame full gamelist for hyperspin xml help needed
« Reply #1 on: August 31, 2009, 11:34:20 am »
I'd be happy to work through this with you.
I'm at work at the moment, and can't get to rapidshare, but shoot me a PM with your email address and we'll get to the bottom of it.  Make sure you're using the latest romlister too; I just fixed an XML formatting issue in it.
abispac
« Reply #2 on: August 31, 2009, 03:34:35 pm »
ok, so you are the romlister guru, glad i found you...  :cheers: anyway, ill download romlister again and see what happens, ill let you know.. thanks
NOP
    • winterMAME
« Reply #3 on: August 31, 2009, 09:42:53 pm »
I'd like to know what errors you fixed to get you to where this file is now (so I can fix them on my end too), and to help some more, you should send me a hyperspin list that does work, so I can try and duplicate it.
admittedly, there has been very little hyperspin testing done to the outputed lists, since I don't use that FE.
we'll get there.  I'm working on the next release right now, so while I've got my hands dirty, we'll fix this up in no time.
abispac
« Reply #4 on: September 01, 2009, 02:19:14 am »
The xml file does not like the "&" character, i get a white space error, so i had to replace that with "and"  and no white space error, the second problem, i get some weird lines  (alot) about <input> <controller type><video> and stuff like that wich give me some weird erros at the xml output, so i errased that as well, and the xml file comes out ok with no errors at a software i use to very the xml, but somehow hyperspin still dosnt read the list, hope i make myself clear sometimes my english its very limited... thanks for the help. i attach a working hyperspin list, its a small one...
headkaze
  • 0x2b|~0x2b?
« Reply #5 on: September 01, 2009, 08:51:25 am »
Changing "&" to "&amp;" should work.
NOP
    • winterMAME
« Reply #6 on: September 01, 2009, 02:30:02 pm »
added the & -> &amp; fix.
I'm not seeing any extra tags that say <controller type> or <video> in my sample list though.
I get things like this:
<menu>
<game name="005">
<description>005</description>
<cloneof></cloneof>
<manufacturer>Sega</manufacturer>
<year>1981</year>
<genre>Maze / Shooter Small</genre>
</game>
<game name="600">
<description>600</description>
<cloneof>turtles</cloneof>
<manufacturer>Konami</manufacturer>
<year>1981</year>
<genre>Maze</genre>
</game>
<game name="7jigen">
<description>7jigen no Youseitachi - Mahjong 7 Dimensions (Japan)</description>
<cloneof></cloneof>
<manufacturer>Dynax</manufacturer>
<year>1990</year>
<genre>Tabletop / Mahjong *Mature*</genre>
</game>
<game name="abscam">
<description>Abscam</description>
<cloneof>puckman</cloneof>
<manufacturer>GL (US Billiards License)</manufacturer>
<year>1981</year>
<genre>Maze</genre>
</game>
</menu>
Are you sure you didn't do a normal XML file and not a hyperspin output?
abispac
« Reply #7 on: September 04, 2009, 03:04:46 pm »
sorry for the delay, ill try the new romlister and post results...
abispac
« Reply #8 on: September 05, 2009, 08:12:01 pm »
Hve you uploaded the new romlister version? cus i get the same errors, heres an example of the extra lines i get:
      <manufacturer><unknown> &
      <display type="raster" rotate="90" width="256" height="224" refresh="60.606061"/>
      <sound channels="1"/>
      <input players="1" buttons="1" coins="2" service="yes">
 Thanks for your time...
NOP
    • winterMAME
« Reply #9 on: September 08, 2009, 10:04:23 am »
ok, please post the text from the -find window for me here; you're seeing drastically different results than I am.
(or we can take this offline if it's easier; my email address is on the romlister website)
You may have to zip and mail me your xml file that you're using for your source too.
I just did a list with over 1000 ROMs in it, and "display type" or any of the other tags you're seeing don't show up at all.  This is a stumper.
abispac
« Reply #10 on: September 08, 2009, 01:27:14 pm »
my problem was, i was using multimame to create a full list, but if i use mame , i do not get any of the extra lines, but still hyperspin does not recognises the gamelist, i noticed that hyperspin gamelist are a bit diferent that yours, just to set an example hyperspin list its like this
<menu>
   <game name> example name<game name/>
and yours comes out like this :
<menu>
im no xml expert so i couldnnt tell if it matters the space betwen the menu and the name tags...
sorry i coulndt take this offline as im at work most of the time...
NOP
    • winterMAME
« Reply #11 on: September 08, 2009, 01:34:07 pm »
when you get a chance, please zip and send me a working hyperspin file and I'll attempt to duplicate it.
email address is on the romlister page.
headkaze
  • 0x2b|~0x2b?
« Reply #12 on: September 08, 2009, 10:02:24 pm »
No it doesn't matter you can have as much or as little space between tags and still have a valid xml file.
