Author Topic: coil arcing?  (Read 5015 times)
lows10blazer
  • Last login:March 11, 2010, 03:09:03 pm
coil arcing?
« on: August 26, 2009, 04:40:49 pm »
hi i have a street fighter alpha system, and when i went to turn it on i heard a loud sparking noise, so i took the back off and found that the coil is arcing on the mounting bracket and just sparking in general what can i do to fix this? i would rather get a whole new board then try to solder/unsolder the coil. i can post pics tonight if you guys need.
grantspain
Re: coil arcing?
« Reply #1 on: August 26, 2009, 04:50:31 pm »
post a pic of the coil you mention
lows10blazer
Re: coil arcing?
« Reply #2 on: August 26, 2009, 05:21:20 pm »
ok i have them on my computer at home i will post them tonight
lows10blazer
Re: coil arcing?
« Reply #3 on: August 26, 2009, 10:24:02 pm »
thats whats sparking im pretty sure it the coil
sarge
  • Last login:April 27, 2015, 01:42:54 pm
Re: coil arcing?
« Reply #4 on: August 26, 2009, 10:30:28 pm »
That is a flyback transformer.  If it is arcing you should replace it.  Doing so will require you to discharge your tube first though.
lows10blazer
Re: coil arcing?
« Reply #5 on: August 27, 2009, 12:12:55 am »
that will require unsoldering/soldering right? and does anyone kno what model this is??? i looked on http://www.jomac.net.au/mon.htm but didnt see it.
endrien
  • Last login:August 08, 2010, 08:33:36 pm
Re: coil arcing?
« Reply #6 on: August 27, 2009, 12:46:27 am »
Yes it will require soldering. Look for some kind of identification as to what model etc the monitor is.
lows10blazer
Re: coil arcing?
« Reply #7 on: August 27, 2009, 01:11:51 am »
is says this on the monitor
g-a63adg25x
04rc0105-009
endrien
Re: coil arcing?
« Reply #8 on: August 27, 2009, 01:40:52 am »
Ken Layton
  • Guru
  • Technician
Re: coil arcing?
« Reply #9 on: August 27, 2009, 01:54:05 am »
It's a Wells-Gardner k7000 series and it definitely has a bad flyback.
Kevin Mullins
    • Me on Myspace
Re: coil arcing?
« Reply #10 on: August 27, 2009, 12:33:39 pm »
Ditto ..... Wells Gardner K7000
And that flyback looks like it's been wacked.
Along with the neckboard not completely seated.
Common monitor, parts readily available, easy to fix.
lows10blazer
Re: coil arcing?
« Reply #11 on: August 27, 2009, 06:23:01 pm »
ok where would i get parts for this at? and how do i re-allign the neck board?
lows10blazer
Re: coil arcing?
« Reply #12 on: August 29, 2009, 12:00:55 am »
bump.....anyone?
Kevin Mullins
    • Me on Myspace
Re: coil arcing?
« Reply #13 on: August 29, 2009, 01:23:36 am »
Bob Roberts is one of several sources....
http://www.therealbobroberts.net/parts.html#flyback
Part Number 053X0528-001  $19.00
Make sure all the pins are lined up properly and gently push it back on.
lows10blazer
Re: coil arcing?
« Reply #14 on: August 31, 2009, 02:06:40 pm »
thanks for the help guys, am i better off getting the flyback and cap kit while im am at it or are the caps harder to install, i have soldered before but only for car audio never on a  board of any sort, how do you unsolder them? just heat the gun the put it on the bottom of the board till the solder turn to liquid?
lows10blazer
Re: coil arcing?
« Reply #15 on: September 09, 2009, 10:21:57 pm »
bump
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: coil arcing?
« Reply #16 on: September 09, 2009, 11:01:21 pm »
radio shack has a relatively cheap desoldering iron that should do the job.
and caps are usually easier to remove than a flyback....
 a solder nooB should always practice technique on a JUNK pcb before attempting the "real thing"
i still do this on occasion with newer surface mount devices. just can't afford to mess up a board there.
lows10blazer
Re: coil arcing?
« Reply #17 on: March 10, 2010, 11:34:22 am »
bump...i am ready to buy this flyback and cap kit are there anyother places other than bob roberts to order from?
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
Re: coil arcing?
« Reply #18 on: March 10, 2010, 12:20:01 pm »
Yes, but what's wrong with Bob?
lows10blazer
Re: coil arcing?
« Reply #19 on: March 10, 2010, 01:20:41 pm »
nohtin i would just rather paypal someone so i dont have to wait for the money order to mail out first, then have him ship my item
MonMotha
Re: coil arcing?
« Reply #20 on: March 10, 2010, 01:57:19 pm »
If you're nice, he'll often cross-ship, so you won't have to wait for the MO to get there.
SirPeale
Re: coil arcing?
« Reply #21 on: March 10, 2010, 08:39:31 pm »
Bob does cross ship.  And if you have a checking account that does online bill pay, you can use that to pay him.  I do that every time I pay him.
  • Last login:Yesterday at 04:23:32 pm
Re: coil arcing?
« Reply #22 on: March 11, 2010, 02:38:11 pm »
is it just me or is the core on that flyback kinked off to the side?!?! it looks busted.
lows10blazer
Re: coil arcing?
« Reply #23 on: March 11, 2010, 03:09:03 pm »
ya i moved it and ya the flyback is busted
Re: coil arcing?
« Reply #24 on: March 11, 2010, 04:27:35 pm »
where you at?, maybe somebody on the board is near you... might have one they would like to part with... (for a fee of course)
