Author Topic: New ps1/ps2 to xbox 360 adapter  (Read 9994 times)
stephenp1983
  • Last login:March 24, 2024, 11:26:39 am
« on: August 23, 2009, 11:35:26 am »
There are a couple of new ps1/ps2 to xbox convertors available now that seem to work alot better than the xfps or mayflash shooter one.  Better yet they alot cheaper..... I picked the Xconvertor 360 up from http://www.renchi.com/renchi/Xbox_360_Accessories_XConverter_360.htm for 24.95 and have been playing sf4 lag free with a ps1 hacked pad.  Like the others you have to have a wired controller plugged in when you start the 360, but after it reads it you can remove it.  Several others have picked up this was as you can grab it off ebay for 9.99, and have had similar posetive results - http://www.superufo.com/product_html/Xbox_1___360_PS2_controller_to_XBOX_360_converter.html
Anyway like I said I have not issues with it at all, and plan to buy another one soon.  Check out the shoryuken forums for some more reviews.....
Dizzle
  • Last login:August 09, 2014, 05:28:04 pm
Re: New ps1/ps2 to xbox 360 adapter
« Reply #1 on: August 23, 2009, 12:29:51 pm »
Thanks for the heads up.   :cheers:  I'll have to check this out...
Cakemeister
  • Last login:May 31, 2024, 06:23:16 pm
« Reply #2 on: August 25, 2009, 02:29:43 pm »
Thanks for the link. I've been looking for an adaptor that will run a Cobalt Flux dance pad and also a guitar controller.
Old, but not obsolete.
Arcadiac
  • Last login:April 14, 2020, 01:26:31 am
« Reply #3 on: October 15, 2009, 12:06:09 am »
Quick question, won't the simple ps2 to usb dongle that works for using ps2 pads on pc work the same on the xbox 360 usb port?
I already have a couple of those around and it would be cool to use them on arcade joysticks for my kid.
Thanks, ARCADIAC!
DJ_Izumi
  • Last login:November 04, 2023, 04:19:22 pm
« Reply #4 on: October 15, 2009, 02:31:13 am »
Thanks, ARCADIAC!
No, while the Xbox 360 uses USB ports, the Xbox 360 controllers are not generic USB game pads.  (USB game pads and generic PS->USB adaptors DO work on the PS3).  The Xbox 360 protocols are propritary and there's encryption between the controller and the system.  Currently only Mad Catz and a few other companies have been given permission and access to construct third party controllers for the Xbox 360.  MS strictly controls the third party accessories now for quality control.  This is why these converts need a standard controller plugged in first, to bypass part of the authentication.
This is why to use an Xbox 360 controller on a PC it doesn't use the same driver as a normal USB Controller.
Arcadiac
« Reply #5 on: October 15, 2009, 02:40:38 am »
So has anyone confirmed this gizmo as working OK?
Thanks again, ARCADIAC
deadpool18
  • Last login:February 03, 2019, 04:22:48 pm
« Reply #6 on: October 17, 2009, 03:04:08 pm »
I just bought two of the Blazepros off Ebay really cheap.  I don't even have a 360 yet, but I figure I might want to hook one up to my Quasicade someday.
« Last Edit: October 17, 2009, 08:54:45 pm by deadpool18 »
Red
  • Last login:November 07, 2017, 08:37:51 am
« Reply #7 on: October 18, 2009, 01:48:07 am »
Are these Blazepros different?  Do you have a link to them?  Thanks.
deadpool18
« Reply #8 on: October 18, 2009, 09:42:23 am »
The Blazepros are the ones listed in the second link in the original post.
Red
« Reply #9 on: October 18, 2009, 03:21:45 pm »
I meant a link to the eBay Seller you bought yours from.  I searched eBay, but couldn't find any Blazepro adapters.  Thanks.
deadpool18
Red
« Reply #11 on: October 21, 2009, 09:43:38 pm »
Great.  Thanks.
Red
« Reply #12 on: October 27, 2009, 11:27:44 pm »
Any lag with the Blazepro adapter?
deadpool18
« Reply #13 on: November 04, 2009, 11:46:05 am »
I'm still waiting to get mine, plus I don't have a 360 yet (maybe I'll pick one up this holiday).  It was reported on shoryuken that there is no lag.
Red
« Reply #14 on: November 05, 2009, 12:43:38 am »
Sounds good.  Thanks.
deadpool18
« Reply #15 on: November 20, 2009, 03:53:56 pm »
I just tested the adapter today.  I didn't notice any lag, but it only worked on my Street Fighter Anniversary stick.  Unfortunately, it didn't work on my Quasicon arcade stick.  :censored:
Red
« Reply #16 on: November 21, 2009, 01:13:15 pm »
Bummer, as I have one of those.  I wonder if any of the other adapters work with the Quasicon stick?
Did you test it on a PS2 Dual Shock controller to see if there was any lag?
Red
