Author Topic: Monitor troubles  (Read 6336 times)
endrien
  • Last login:August 08, 2010, 08:33:36 pm
Monitor troubles
« on: August 20, 2009, 09:49:29 pm »
So I just got a tekken 3 cab and it works/looks fine except the picture is a bit curved in and it spazzes out sometimes. Please don't tell me Its a cap kit, that would be a pain in the ass.
Bent:
Spazz:
Kevin Mullins
    • Me on Myspace
Re: Monitor troubles
« Reply #1 on: August 20, 2009, 10:11:14 pm »
What make and model monitor is in there ?
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #2 on: August 20, 2009, 11:11:04 pm »
1st pic indicates a vertical deflection defect . this symptom type usually caused by low vcc to the vert output ic or defective ic.
2nd indicates instability of Hosc. which , can also be a low vcc issue.
so , there is a strong likelyhood that there are defective 'lytics present.
time to hone your desolder/soldering skills   ;D
endrien
« Reply #3 on: August 21, 2009, 12:15:23 am »
didn't terribly understand what you were talking about with the abbreviations and etc :P, could you sum it up? And I can solder pretty well I just don't want to mess with discharging the monitor..
Kevin Mullins
    • Me on Myspace
« Reply #4 on: August 21, 2009, 01:38:36 am »
I've seen the "spazz" symptom like yours just recently on a K7400...... but that doesn't mean squat without knowing what YOUR monitor is.
qrz is referring to low voltages in the vertical and horizontal oscillation circuits, could be caused by bad capacitors, could be bad IC's, could be bad diodes, could be a number of things.
But knowing what your monitor model is might narrow it down to common failures of said monitor.
endrien
« Reply #5 on: August 21, 2009, 01:40:10 pm »
On the back of the monior it says:
G-A68ACT00X
There are some knobs with vhold,hhold,vpos, etc but they didn't fix any of the problems.
Kevin Mullins
    • Me on Myspace
« Reply #6 on: August 21, 2009, 01:45:43 pm »
G-A68ACT00X
That's just a TUBE number....... all it tells us is it's a 25".
Look for identifying labels on the frame or the circuit board chassis itself.
Or take a pic of the chassis, might be able to narrow it down from there.
endrien
« Reply #7 on: August 21, 2009, 01:49:47 pm »
grantspain
« Reply #8 on: August 21, 2009, 02:27:27 pm »
looks like a kortek/sharp image or A-one chassis
as for the spazzing out-can you explain that some more-i can see what looks like a possible frame foldover on the second pic
endrien
« Reply #9 on: August 21, 2009, 02:45:57 pm »
its like the picture squeezes inwards and a squiggly line jostles about.
grantspain
« Reply #10 on: August 21, 2009, 02:57:24 pm »
the first thing to look for is bad solder joints on the chassis and maybe think of checking out the caps
i am also wondering whether this is infact a prelude to the flyback breaking down
endrien
« Reply #11 on: August 21, 2009, 06:28:31 pm »
I may be picking up a few monitors as well so we'll see. I hope this one is a simple fix.
endrien
« Reply #12 on: August 21, 2009, 11:21:30 pm »
I really want to get this fixed~
endrien
« Reply #13 on: August 23, 2009, 12:37:59 am »
On the board it says "AP-0428"
Kevin Mullins
    • Me on Myspace
« Reply #14 on: August 23, 2009, 01:45:09 am »
First thing I would do is pull the chassis and check for bad solder joints.
endrien
« Reply #15 on: August 23, 2009, 01:47:58 am »
Is there any guide for making your own "high voltage probe"(Screw driver with the grounding clip). I watched the how to discharge a monitor video but Dont really know how to properly make a probe. Also is a monitor the only thing I need to worry about touching while its unplugged(Like does the transformer hold a charge as well?
Kevin Mullins
    • Me on Myspace
« Reply #16 on: August 23, 2009, 03:07:30 am »
http://www.riddledtv.com/repair/journal/DischargeCRT/
Once you discharge it, just stay clear of the hole in the tube.... that's the part that'll get ya.
endrien
« Reply #17 on: August 23, 2009, 07:51:17 am »
By hole do you mean where the place you discharge from?
Kevin Mullins
    • Me on Myspace
« Reply #18 on: August 23, 2009, 09:51:20 am »
Yes, the hole where the anode attaches into the tube.
endrien
« Reply #19 on: August 23, 2009, 11:28:43 am »
the metal frame on the back of the monitor is grounded correct?
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
« Reply #20 on: August 23, 2009, 11:49:24 am »
It's not "grounded", no.  What you're doing when you discharge the tube is dissipating the charge within.
Just get a screwdriver and some wire, bare the ends of the wire, wrap one end around the screwdriver and clip on the other end with a clothespin.  Simple, quick and effective.
Or, I sell them in my store.
endrien
« Reply #21 on: August 23, 2009, 06:16:37 pm »
I put some wire around the screw driver and and put the other end around the monitor frame and it worked fine(I'm talking about the big metal pieces coming out the back.
Nipedley
  • Last login:October 04, 2024, 12:03:26 am
« Reply #22 on: August 23, 2009, 07:09:24 pm »
I would be reluctant to use that due to firstly the wire being very close down near to your hand, and secondly due to the black tape, the wire could become disconnected from the metal and you wouldnt be able to see.
Of course if it worked fine for you then that's great but if you make a Mk. 2 then maybe put it halfway down the handle and some see-through tape just for some piece of mind
endrien
« Reply #23 on: August 23, 2009, 07:45:54 pm »
Well I'm scrapping this monitor anyways I think, but I coiled the wire tightly around the screwdriver, it couldnt move.
SirPeale
« Reply #24 on: August 23, 2009, 08:07:34 pm »
You did just fine.
Don't scrap the monitor, at the very least give it to someone who can fix it.
endrien
« Reply #25 on: August 23, 2009, 09:17:09 pm »
I think I found the problem with the monitor but I don't really want to bother with fixing it. I'm using a PC monitor instead atm. The cab monitor had a few corroded wires and some cold solder points. Nobody lives around here on the forums. Or anyone at all really.
SirPeale
« Reply #26 on: August 24, 2009, 09:54:44 am »
Where do you live?
endrien
« Reply #27 on: August 24, 2009, 10:21:21 am »
Newfoundland canada. I may or may not get around to fixing it, probably will.
casualplayer
  • Last login:July 20, 2013, 03:16:56 pm
« Reply #28 on: July 01, 2013, 07:55:53 pm »
Hello,
I have an A-one AP-0428 board and missing cap #14.
I want to ask a huge favor, can you look on your board and see the value of #14 is?
here is a pic of where the location of it should be.
https://www.dropbox.com/s/f2s5tnczn93rhnb/C14.JPG
Thank you
so much.
