Author Topic: SkeeBall Help  (Read 7506 times)
coyote640
  • Last login:June 08, 2021, 06:58:35 am
SkeeBall Help
« on: August 19, 2009, 01:02:04 pm »
 ;D I just got my SkeeBall Machine home, I've been looking for one for months....
I need some help Identifying this Beast... Because I need a part for the scoreboard.
Upon Inspection, I can't find any tags whatsoever on or in the machine....
The Marquee shows Fab U Ball on it... but searching comes up empty...
As you see in the pics, I am missing the red plastic part that covers the light bulbs under the marquee on the scoreboard.
Any idea on what I could use to replace this???
Here's the link to the pics...
http://s766.photobucket.com/albums/xx309/coyote640_bucket/
Thanks.....
  • Last login:July 23, 2025, 07:04:20 pm
Re: SkeeBall Help
« Reply #1 on: August 19, 2009, 01:05:09 pm »
Get a piece of plexiglass, paint the insides with a design, and place it over the blank spot?  Or even get something printed on marquee material, sandwich it in some plexi, and put it up there.
coyote640
Re: SkeeBall Help
« Reply #2 on: August 19, 2009, 01:31:23 pm »
Thanks, but as you see in the pics, I have the marquee already, it is just the underlay that goes over the lights. Is it just a red celefain? As in the pic, the bulbs are clear, but when lit, they should outline a number....
Re: SkeeBall Help
« Reply #3 on: August 19, 2009, 02:01:22 pm »
Ahh gotcha.... I see.  You could try some cellophane, sure.  Whatever looks good.
coyote640
Re: SkeeBall Help
« Reply #4 on: August 19, 2009, 07:13:09 pm »
 ??? Anyone seen this before, I would like to get a schematic. I can get the balls to come down, sensors will blink and count 9 balls before it starts catching them again. But the game won't reset and start. I believe I should get the ALLEY OPEN light to come on when it is ready. Right now it is just stuck in the demo mode, flashing lights, playing music. There is a reset button which just starts it over, and a service button which goes through some light sequences to show all the lights working.
Any help or suggestions will be appreciated....thanks.... :banghead:
Kevin Mullins
    • Me on Myspace
Re: SkeeBall Help
« Reply #5 on: August 20, 2009, 12:37:10 am »
What does the CPU unit inside the head box look like ?
(behind the light board for the digits)
There's usually a plastic piece that fits over those light bulbs to give it the LED digit look, with each bulb lighting an individual segment.
Overall the layout looks VERY similar to a standard Skeeball brand machine.
Maybe a slightly older Model H or something..... not sure though.
Kevin Mullins
    • Me on Myspace
Re: SkeeBall Help
« Reply #6 on: August 20, 2009, 12:40:58 am »
Oh, and I would start with pulling the main boards out and thoroughly re-seating every chip on it and look for bad solder joints and such around the power supply sections and any header pin connectors. Clean and re-seat and wiring connectors, etc. Just general stuff.
Just common problems you find with any regular Skeeball brand machine, so I would apply the same concept to this one to start with.
coyote640
Re: SkeeBall Help
« Reply #7 on: August 20, 2009, 10:08:13 am »
Thanks for the Help..... Yes it is the red plastic LED cover I need, I drove over 3 hours for this machine, and I lost it in transit......
I updated the pictures that show the inside behind the lights, it is definitely not like an arcade board that I am used to working with....
I emailed Skeeball.com too, to see if they can help in the identification also... but anyone with an extra 3 digit LED cover please let me know.
Or if this looks similar to a model H, give me a heads up....
Sorry, this is my first Skeeball machine, and just getting into it. Arcade units and my mame cabinet were much easier to work on for me.....
Kevin Mullins
    • Me on Myspace
Re: SkeeBall Help
« Reply #8 on: August 20, 2009, 12:58:20 pm »
Take a quick measure of the digit display area (the blank box area) and the spacing between bulbs and maybe we can see if it matches a standard Skeeball display piece.
I have an old Toss Em' machine and it also has a very similar display setup as the Skeeball version. (speaking about the red plastic display piece) I haven't pulled it off to take any measurements yet, but I'm guessing the part you lost shouldn't be terrible to get a hold of. I may even know where a Skeeball version is laying around. (have to double check this weekend)
« Last Edit: August 20, 2009, 01:27:11 pm by Kevin Mullins »
Encryptor
  • Trade Count: (+34)
  • Last login:December 21, 2023, 08:01:18 pm
Re: SkeeBall Help
« Reply #9 on: August 20, 2009, 05:07:31 pm »
Is it just a piece of red acrylic or is it masked of for each number area?
Maybe you could get something like this and make your own.
http://www.plasticonline.co.uk/index.php?act=viewCat&catId=4
Encryptor
Kevin Mullins
    • Me on Myspace
Re: SkeeBall Help
« Reply #10 on: August 20, 2009, 09:15:10 pm »
Here's a pic from UncleT of his machine I snagged that shows the digit piece pretty well.
(and my poor example of the bulb layout)
It's more or less just a plastic "box" that fits over each individual light bulb with cutouts to mimic the segments of an LED display and then that whole piece has a piece of red acrylic of sorts to cover those segments so that they show as red "segments".
I believe UnclkeT's machine is a Model H Skeeball..... the Model S Skeeballs aren't much different.
« Last Edit: August 20, 2009, 10:12:19 pm by Kevin Mullins »
RichSorr
  • Last login:August 29, 2015, 07:27:00 pm
Re: SkeeBall Help
« Reply #11 on: August 21, 2009, 09:41:59 pm »
You can use a piece of red acrylic or red litho tape. litho tape is what skee ball uses on a lot of their displays. Finding it wide enough can be tough though.
coyote640
Re: SkeeBall Help
« Reply #12 on: August 23, 2009, 02:18:07 pm »
Thanks to everyone.....
Kevin, here is a pic with the measurements.....
And a pic of the boards.... to help see what I have and to figure out what the dip switch setting are.
I will also pull the re-seat everything and check stuff over to see what the reset problem is.
Kevin Mullins
    • Me on Myspace
Re: SkeeBall Help
« Reply #13 on: August 23, 2009, 02:49:28 pm »
Cool... I'll try to measure a regular Skeeball version up as soon as I can get ahold of one.
(didn't get down to location yet)
coyote640
Re: SkeeBall Help
« Reply #14 on: August 23, 2009, 02:58:23 pm »
Thanks alot.... this is much appreciated.
On the CPU it says FAB 002 and there is a sticker on one of the chips "FAB U3 1pt 11/15/04. A sticker on the back reads: "F.A.B. Electronics Co., Inc. Pleasantville, NY 10570 (914) 769-5104
