Author Topic: Pushbutton to LED - noob wiring question  (Read 1041 times)
iammortos
  • Last login:February 08, 2010, 07:26:55 pm
« on: August 18, 2009, 07:00:52 pm »
Hi guys,
I was thinking of wiring a led to the "coin" buttons on my control panel
most of you will know what this means here i would think, but heres a basic drawing of what i want to happen
button goes to the xarcade system, has ground and power wires
for example:
red - power
blue - ground
i want to pop a LED in there somewhere sowhen the switch is pressed (completed) the LED comes on
anyone have a basic answer for this? i can draw up a diagram in paint if need be :)
thanks alot
mlalena
  • Last login:June 12, 2021, 12:31:44 pm
Re: Pushbutton to LED - noob wiring question
« Reply #1 on: August 18, 2009, 08:32:58 pm »
I don't think this is a good idea.
Option 1) Assuming the XArcade circuit to each button was 5V. Then you could wire your LED (probably around 2V) and a resistor (to drop the 5V to 2V) in series with the button. Problem here is that the LED is drawing current and resistor is adding resistance to the circuit. The XArcade is not expecting a power draw or resistance.
Option 2) You wire the coil of a relay in series with the button. When the button is pressed, you complete the circuit on the relay. You can then wire the 5V power from USB or a hard drive connector in the case through the relay to a resistor and a LED. Again, the coil in the relay adds some resistance, although a solid state relay shouldn't.
Option 3) Purchase a special button that has a separate built in light with separate 5/12V power lines that lights up when lit. This is the only method I would recommend. Ex: http://www.allelectronics.com/make-a-store/item/LPS-4A/12V-LIGHTED-PUSHBUTTON-AMBER-1-SQUARE/-/1.html
Also, if you were to do this, I don't think you would be happy with the result. A button that was lit up only when your finger was on it??? I think an always lit button would look better.
iammortos
« Reply #2 on: August 18, 2009, 10:11:18 pm »
thanks for the info, will have to think about this another way :)
The reason for thiswas to have a "eye" light up each time the coin button was pressed, but im sure i can find anotehr way of doing this
Cheers :)
might use the hdd activity led ;)
