Author Topic: Neotec 36" 3501 Chassis RCA Tube Advice Pls  (Read 1687 times)
supadave
  • Last login:June 11, 2023, 09:10:08 pm
« on: August 17, 2009, 09:18:11 pm »
A showcase cab I'm looking at has one of these in it. However, the picture is dim. I turned the brightness up on both the control and flyback. No go.. Is this more than likely a Tube problem or is it chassis related?  The tube is an RCA btw. I do not want to have any part of this if the majority believe it to be a tube issue. A chassis issue I can deal with.. I'm just looking for some feedback from some more experianced monitor techs..
supadave
Re: Neotec 36" 3501 Chassis RCA Tube Advice Pls
« Reply #1 on: August 18, 2009, 06:15:34 am »
Also, What about a tube swap.. Are those possible on the big 36 inchers?
grantspain
« Reply #2 on: August 18, 2009, 02:48:58 pm »
could be just a few leaky caps causing the problem,i guess you have tried all the colour gains and contrast
supadave
« Reply #3 on: August 18, 2009, 08:27:54 pm »
Yeah I have tried all the gains could find.  I've been getting some tips from some users and it sounds more and more like a chassis issue. which is good... well, cheaper than tube issues.
