Author Topic: Help! Mala / Ledblinky issues  (Read 1591 times)
« on: August 07, 2009, 12:34:46 pm »
All I want to do is light the controls active for each game.  I think I have everything setup, but it doesn't do anything.
Re: Help! Mala / Ledblinky issues
« Reply #1 on: August 07, 2009, 12:42:32 pm »
Using an Ipac-4 and 4 LED-Wiz's.
arzoo
  • Robots WILL kill you.
    • LEDBlinky
« Reply #2 on: August 10, 2009, 01:21:44 pm »
Turn on the Debug Log and Verbose options, run MaLa, launch some games, then email me the debug.zip file (in the ledblinky folder).
Robots will kill you.
Arcade Addiction
« Reply #3 on: August 10, 2009, 02:32:10 pm »
Will do.  You are the man! :)
« Reply #4 on: August 11, 2009, 07:34:26 pm »
Sent.  Also, the audio animation... I test and save it as:
Color / Intensity Spectrum (LED Brightness based on amplitude) with the locked frequency (so all buttons behave the same).
However, when it runs in MALA, it runs as if the Lock Frequency is unchecked (even though when I check it, it is checked) and so all the buttons behave differently.
