Author Topic: Auto it! for PSX emulator  (Read 2028 times)
TeutonicDarkness
  • Last login:July 16, 2019, 10:54:16 pm
« on: August 07, 2009, 12:06:37 am »
Hello,
 I currently have a HotRod SE so I use the Key "c" to close
all my emulators instead of esc.
I have most of them down but I need a solution to
to use C instead of esc.
I'm currently launching games from Batch files compiled
into exe.
Does anyone know how to close a exe by sending key press "c"
using Auto IT?
I would be very grateful.   :)
gonzo90017
Re: Auto it! for PSX emulator
« Reply #1 on: August 07, 2009, 01:52:49 pm »
TeutonicDarkness
« Reply #2 on: August 07, 2009, 08:02:26 pm »
Why not just use closemul?
http://lustar.free.fr/clusters/closemul/
Never could get it or various others to work with PSX... :(
TeutonicDarkness
« Reply #3 on: August 13, 2009, 08:40:06 pm »
Well The biggest reason is I would need multiple instances of
closeeul I can't get it to work on 1 instance.
I don't  know but I'm not sure if Closemul
support several instances of itself?
 Well Anyway moving on.....
I have found a solution that works nicely!
I'll ever share to help other users... :)
You will need Auto Hot Key!
Here is one of my scripts as a example (Resident Evil 3.ahk):
Code: [Select]
run Resident Evil 3.bat
c::
Send, `{F4}{ALTDOWN}{F4}{ALTUP}
#SingleInstance force
run process -q AutoHotkey.exe
run process -k psxfin.exe
 You will also notice the above "process" you will
have to download this file and drop it in system 32 folder.
Very handy tool I might add!   :)
Hope this helps someone.    ;)
