Author Topic: Cool pinball related circuits from Jeri Ellsworth  (Read 4793 times)
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
Re: Cool pinball related circuits from Jeri Ellsworth
« Reply #1 on: August 06, 2009, 11:02:35 am »
That is awesome!
Electrical engineering has always been my achilles heel. Software I can do in my sleep, but capacitors, darlington pairs, thiristors, ack!
Very cool and nice explanation too.
digitaldj
« Reply #2 on: August 07, 2009, 09:02:32 pm »
In the first video way to much circuit is used for a simple problem. When the lights are used in (what she called a grid), which is actually called a matrix.When you have the scanning freq it is just a squarewave output on the matrix lines. This is almost the same as rectified A/C and with a capacitor becomes D/C. So as long as you filter that square wave with a capacitor you eliminate the flicker because now it is D/C. Just a simple elecrolytic capacitor will solve the problem.
A cap on each led will do the trick along with the current limiting resistor.
« Last Edit: August 07, 2009, 09:04:18 pm by digitaldj »
digitaldj
« Reply #3 on: August 07, 2009, 09:31:55 pm »
I forgot to add the diode, you will need a diode, cap & current limiting resistor on each l.e.d.
SirPeale
« Reply #4 on: August 08, 2009, 09:36:22 pm »
Digital DJ: you should tell her that.  I'm curious what she'll say.
digitaldj
« Reply #5 on: August 08, 2009, 09:49:32 pm »
Actually I got to thinking about it and each led doesn't have to have a diode and cap it can be done on each pulsed line of the matrix. This makes it even more simpler.
I will post on her page and see what she says.
digitaldj
« Reply #6 on: August 08, 2009, 10:10:40 pm »
Sir Peale,
Where is your store? I tried to go there but i'm getting nothing!
Kevin
SirPeale
« Reply #7 on: August 09, 2009, 07:42:06 am »
I'm having server issues @ the moment.
digitaldj
« Reply #8 on: August 09, 2009, 06:31:45 pm »
Send me an email when your up.
SirPeale
