Author Topic: AAARRRRRRRGH! Or, how I managed to slide an SD card in my A drive slot  (Read 2701 times)
RTSDaddy2
  • Last login:April 03, 2014, 08:28:03 pm
  • Bees! Oh bother!
 :banghead: :banghead:  :banghead:  :banghead:
Well, as if I didn't have enough going on.  I went to put my SD card from my Wii into the SD slot on my PC to do some work on it....and as MANY TIMES as I've done so in the dark, this time I missed my slot and my brain went "Damn that feels large...." just about the time I let go of the front edge of the card and realized what I'd done....I'd inserted the SD card into our 3.5 floppy drive!
To the positive, it really doesn't hurt things too much. For the moment, I've lost Wii save data, but really no biggie...can recreate all of it in short order.  We really don't use the 3.5 floppy drive much anymore either, so no real loss there at the moment either.  Just frustrating as hell - wife will probably want to kill me in the morning.
Is it very hard to take a 3.5 drive out of a PC and apart?  :D
crashwg
Re: AAARRRRRRRGH! Or, how I managed to slide an SD card in my A drive slot
« Reply #1 on: August 01, 2009, 01:46:40 am »
Shouldn't take more than 5 minutes to get the drive out and apart enough to get the card out.  Once you get it out chuck the floppy drive in the trash and press F12 or Del or whatever your motherboard requires and uncheck  whatever setting there might be for the floppy drive...
Or you could go at it with a flashlight and some tweezers.  Make sure you turn the PC off first.
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
Nipedley
  • Last login:October 04, 2024, 12:03:26 am
« Reply #2 on: August 01, 2009, 06:08:22 am »
I was going to say, if it was me I'd have a go with tweezers it should be that difficult to grab, if you couldn't get it vertically (there should be some room but nontheless) you could always get it horizontally. Maybe even a small pair of scissors or something. Worst case scenario take the side of the case off, unscrew floppy drive, cables out and job done :)
I've done similar things myself, usually trying to fit a micro sd or a sony MS duo into my laptop's sd slot, forgetting they need a converter... Tweezers worked wonders there
« Reply #3 on: August 01, 2009, 07:12:44 am »
wow, you have a floppy drive? at least you didnt say 5 1/4 floppy
Cakemeister
  • Last login:May 31, 2024, 06:23:16 pm
« Reply #4 on: August 01, 2009, 11:00:54 am »
My wife once tried to put a CD-ROM in a 5 1/4" floppy drive. It didn't work.
Old, but not obsolete.
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #5 on: August 01, 2009, 03:59:52 pm »
I doubt that you need to take it apart.  Just slide it out of the PC, turn it so the slot faces the floor, hold open the little door and shake until your card falls out.
Best Kid iPad Apps
RTSDaddy2
  • Bees! Oh bother!
« Reply #6 on: August 01, 2009, 07:58:54 pm »
The shake thing worked.  The reason it didn't work last night when I first got the  :censored: thing stuck was because Zippy here forgot to hold the drive door open so it COULD fall out.   :dunno    :banghead:
When my wife helped with it this morning, it just plopped right out.  Took the whole amount of 2 seconds.   ;D
Well, at least it wasn't a major fix!  Thank y'all! :)
(and just for the record - Malenko, man do you honestly think I'd have told THIS crowd what size floppy drive I have?  I'd have never heard the last of it had it been 5 1/4   :laugh2:)
« Last Edit: August 01, 2009, 08:01:13 pm by RTSDaddy2 »
Ginsu Victim
  • Comanche, OK -- USA
« Reply #7 on: August 02, 2009, 10:46:23 am »
This was my first thought. It was the most obvious route.
protokatie
« Reply #8 on: August 03, 2009, 12:25:48 pm »
Gimme back my C64 with its completely infalable and parfect 1541 drive! Hell, I'll even take my ol' C128D and CP/M disks over the POS's they make these days... (and yes, I am THAT OLD)  :cry:
EDIT: Forgot to misspell perfect as well... (anyone who has ever owned a 1541 knows why I did that)
« Last Edit: August 03, 2009, 12:30:33 pm by protokatie »
CCM
« Reply #9 on: August 03, 2009, 12:49:27 pm »
ahh the old 1541!   I was cleaning out our storage area yesterday and came across my C64,  2 1541 disk drives, and my old EPYX joystick!  I am going to set it up this week and see if they still work!
protokatie
« Reply #10 on: August 03, 2009, 01:15:27 pm »
The C64 and Joy will, but I would bet dollars on pounds that both 1541's are bricked... :<
Good on the find tho, bet that sent your mind back 20 years! :laugh: :laugh:
CCM
« Reply #11 on: August 03, 2009, 01:41:31 pm »
It sure does!  I just wish I still had all my old games.  I was stupid and gave them away years ago.  The ones I do still have are:  Bards Tale 1 and 3, Might and Magic 2, and Pool of Radiance.
protokatie
« Reply #12 on: August 03, 2009, 02:03:17 pm »
DORK!
Ok, you can't be a full dork if you dont have Zork 1,2 and 3 (and maybe Zork zero)
You enter a storage area. There is dust here.
You see a canvas cloth covering some objects.
It is dusty, you are likely to sneeze alot.
The exits are to the south and east.
RTSDaddy2
  • Bees! Oh bother!
« Reply #13 on: August 04, 2009, 05:26:43 am »
Then I definitely qualify as dork by Katie's standards...had all four.
danny_galaga
  • Last login:Today at 12:07:45 am
    • dans cocktail lounge
« Reply #14 on: August 04, 2009, 05:41:40 am »
What is this 'floppy drive' of which you speak? :duckhunt
« Reply #15 on: August 04, 2009, 09:28:52 am »
No mangle needed.
CCM
« Reply #16 on: August 04, 2009, 10:54:04 am »
DORK!
I definitely had Zork 1, 2, and 3 along the way.  I'm pretty sure I still have the PC version of Zork 1.   Back in the C64 days, I actually spent hours mapping out Zork 1 on graph paper!
CCM
