Author Topic: Which build of MAME works with ActLabs guns?  (Read 964 times)
nickynooch
  • Last login:August 29, 2020, 02:54:00 am
« on: July 31, 2009, 11:53:26 am »
Basically I have the regular windows command line version of MAME.  Trying to set up the Act Labs guns and wondering if I need to get (MAMEUI, MAME32, etc) or something to get it to work.  I've seen the tutorial on Act Labs site, but just curious if maybe I need a different build of mame.
I think I have MAME .125 with the no-nag patch.
Thanks,
Nooch
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: Which build of MAME works with ActLabs guns?
« Reply #1 on: July 31, 2009, 05:36:11 pm »
Since mameUI is basically the same as mame, and lightgun support was repaired somewhat recently, what you are concerned with is version number
...I think I have MAME .125 ...
I couldn't find exactly when the fix was made (in my quick 2 minute search), but IIRC you have a version that was before the fix, but after it broke.  The current version is fixed.  Or you could go older.  I'm not sure on exact numbers, though.
Robin
Knowledge is Power
