Author Topic: New project announcement on Mame box  (Read 2285 times)
cbowman
  • Last login:September 27, 2009, 04:03:13 am
« on: July 30, 2009, 04:41:24 pm »
Well I wanted to write it here that I got the bug and I need to make a mame box. I am new here so I want to say hi. My goals on this project are to make a box that looks more like a piece of furniture so i can put it in the living room instead of just a traditional look. It is a 4 player box with a 27" monitor. I just got my order for my joysticks from ultimarc and I got 4 - Mag-Stik Plus', and an ipaq4. Next up is to order the buttons and trackball. Below is an example of what i really want mine to look like but with a 4 player control set and hyperspin-fe front end.
Once again thanks for a great forum.
~Curtis~
Status Update: 8-4-09 all buttons ordered for machine.
« Last Edit: August 04, 2009, 03:39:35 pm by cbowman »
  • Last login:Yesterday at 07:32:51 pm
Re: New project announcement on Mame box
« Reply #1 on: July 30, 2009, 05:23:39 pm »
Nice - you might want to check out Knievel's Woody thread since he is the one who came up with the design (and his looks a thousand times nicer).  I can't believe they are charging $3,000 for that thing!  I'd think about whether you need a 4P machine and a 27" monitor.  It will be a HUGE cabinet if you go that route and probably won't fit into a living room no matter what it looks like.
« Reply #2 on: July 30, 2009, 06:37:41 pm »
That'll be a good project. Are you doing a 27" LCD or a 27" tube monitor.
I'd think an LCD is the way to go for something like this, otherwise Javery's right, it'll be a huge cab.
I too think you could likely do better than that cab. Put some cabinet panels on the sides, so trim, something along those lines.
Heck maybe even grab a tambour and make it a rolltop arcade cab!
Good luck!
cbowman
« Reply #3 on: July 31, 2009, 11:55:16 am »
i am actually doing a 25" LCD I just ordered.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4312740&CatId=3774
so all thats left is buttons and trackball and spinner and i can start the woodworking.
