Author Topic: Daphne 1.0 Setup Issues - Help Please...  (Read 6717 times)
zmartin34
  • Last login:December 26, 2011, 09:22:42 pm
« on: July 29, 2009, 09:46:22 pm »
I finally got Daphne up and running. I'm using Loader v1.0 on Vista 64 w/ an ArcadeVGA. Works just fine as long as I have OpenGL selected (otherwise I get a black screen; sound only) except for one very annoying issue:
When I enable full screen mode it gives me an error: "no video mode large enough for 640x480" and won't load the game at all!
Got to be a driver issue right? I'm scared to know the answer...
« Last Edit: August 04, 2009, 05:29:51 pm by zmartin34 »
zmartin34
Re: Daphne 1.0 and ArcadeVGA - Fullscreen issues
« Reply #1 on: July 29, 2009, 10:49:56 pm »
Well I wrote to soon. The full screen issue is one problem. The other problem is that the game hauls ass! lol I mean really hauls!
The boot-up screens go by VERY fast. I am then able to enter two coins w/ the 5 key and start with the 1 key. At this time I seem to catch like 4-8 seconds of each clip. I am not able to control anything it just skips right along to the next movie every 5 seconds or so.
Oh yea, whenever I click change under the 'input' tab while configuring at the Loader GUI I get an error "input_grabber.exe has stopped working."
I'll search this out but any help is appreciated.
Section_25
  • Last login:February 12, 2010, 08:35:29 am
« Reply #2 on: July 30, 2009, 08:08:14 pm »
I don't use an arcadeVGA so I'm affraid I can't help with the resolution problem. You might want to contact the the place you purchased it from for assistance with that. I'm also not 100% sure about your "Speed" problem in Daphne. If I remember correctly, I think Daphne runs through all of the mpegs and creates it's own files to go along with them when the program runs the first time. Does this speed problem occur everytime you run the game? Have you let it run to see if it auto corrects itself? Let us know  ;)
---MAME Arcade Cabinet---
Hyperspin FE
LED Blinky
http://i263.photobucket.com/albums/ii133/Section_25/Mame%20Cabinet/Front.jpg
Join me on My IRC Network at:
www.irc-section.net
zmartin34
« Reply #3 on: July 31, 2009, 08:46:01 am »
OK, I'll email Andy @ Ultimarc about the fullscreen issue as its prob driver related.
In terms of the game hauling, yes, it happens every time. I get a few seconds of the clip and then it bounces to the next clip. Occasionally in between clips I'll see a parsing status bar for a second. It goes from clip to clip and I can't control anything.
I think I need to take this to the Daphne board. Not sure if there are compatibility probs with Daphne and Vista x64 maybe?
Thanks for taking a second. Also, I'll post up a link to my thread on the Daphne board if I do that.
zmartin34
« Reply #4 on: July 31, 2009, 08:48:17 am »
A quick search at the Daphne board said that you must allow the loader to update itself which i did not. I'll update and then check back. This should fix ALOT of probs hopefully.  ;D
zmartin34
« Reply #5 on: August 04, 2009, 12:59:52 pm »
Well I left it update itself but only the loader updated. The version of Daphne remained the same @ v1.
I'd really like to just get the game to play right and worry about the driver issue later. Would someone be willing to post the command line that works for them to launch Dragons Lair?
This may be useful to sort out the proper options.
zmartin34
Re: Daphne 1.0 Setup Issues - Help Please...
« Reply #6 on: August 04, 2009, 05:32:24 pm »
Here is my log file:
--DAPHNE version 1.0.0
--Command line is: daphne.exe lair vldp -framefile C:\HyperSpin\Emulators\Daphne\framefile\lair_HD.txt -ignore_aspect_ratio -blank_searches -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir . -fastboot -bank 0 11111001 -bank 1 00100111 -noserversend -sound_buffer 2048 -x 640 -y 480 -opengl
--CPU : GenuineIntel 3450 MHz || Mem : 4096 megs
--OS : Windows NT/2000 || Video : Ultimarc ArcadeVGA2
--OpenGL: Compiled In
--RGB2YUV Function: MMX
--Line Blending Function: MMX
--Audio Mixing Function: MMX
Setting alternate home dir:
Setting sound buffer size to 2048
Setting screen width to 640
Setting screen height to 480
Set 640x480 at 32 bpp with flags: 2
Initializing sound system ...
GI Sound chip initialized at 2000000 Hz
Joystick #0 was successfully opened
Remapping input ...
Loading compressed ROM image dl_f2_u1.bin...8192 bytes read.
Loading compressed ROM image dl_f2_u2.bin...8192 bytes read.
Loading compressed ROM image dl_f2_u3.bin...8192 bytes read.
Loading compressed ROM image dl_f2_u4.bin...8192 bytes read.
Framefile parse succeeded. Video/Audio directory is: C:/HyperSpin/Emulators/Daphne/framefile/./
OpenGL v2.0 is supported.
Booting ROM ...
Play
LDP : disc is already playing, play command ignored
Play
Display disable received
Search to 323 received - [25] Attract Mode, Sequence 0 Attract Mode
NOTE: converting FPKS from 23976 to 29970. This may be less accurate.
search succeeded d0
Play
Search to 306 received - [25] Attract Mode, Sequence 0 Attract Mode
Freeing memory used to store audio stream...
search succeeded d0
LDP NOTE: ignoring seek because we're already on that frame
search succeeded d0
Search to 1424 received - [ 0] Introduction, Sequence 0
search succeeded d0
Play
Search to 1823 received - [ 0] Introduction, Sequence 3
search succeeded d0
Play
Shutting down sound system...
Shutting down video display...
Thanks to anyone who can help me at all... I'm stuck  :banghead:
zmartin34
« Reply #7 on: August 09, 2009, 12:30:52 am »
OK, well the prob was a bad rom file. A friend sent me his command line and that set me straight. Also, working very well within Hyperspin FE.
So the only prob I'm left with at this point is the full screen issue. Going to email Andy @ Ultimarc, maybe he can shed some light...
Thank you Section
Section_25
« Reply #8 on: August 11, 2009, 06:20:34 am »
Thank you Section
Not a problem bud!!
I'm glad you got it somewhat straightened out. The laser disk games are great to have for an occasional game or two  ;)
Hyperspin FE
LED Blinky
www.irc-section.net
