Author Topic: any trick to crimping wires into a disconnect  (Read 1694 times)
Hoagie_one
  • Um....whats a cabinet
« on: July 10, 2003, 02:10:00 pm »
Just put the wire in and squeeze the bejesus out of it right?
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
Re:any trick to crimping wires into a disconnect
« Reply #1 on: July 10, 2003, 02:40:39 pm »
Well...yeah!  It's even easier when you use a crimper.
OSCAR
  • Last login:September 06, 2018, 11:31:53 pm
  • I think Bigfoot is blurry, that's the problem...
    • Oscar Controls
« Reply #2 on: July 10, 2003, 11:10:02 pm »
The only real trick is to make sure you have the right size disconnect for the wire you are using.  Using a blue disconnect on 22ga wire wire make for a sloppy connection that won't hold well.  Generally speaking:
22-16ga wire = red disconnects
16-14ga wire = blue disconnects
12-10ga wire = yellow disconnects (I can't imagine anyone has ever used these on an arcade cabinet!)
Paul Olson
    • Paul's Arcade
« Reply #3 on: July 10, 2003, 11:17:05 pm »
I had a really hard time getting the 22 gauge to stay in the red connector.  I finally started folding the tip of the wire in half, and I didn't have any problems at all.
Paul
ZippySLC
  • Last login:August 10, 2003, 08:15:00 am
  • Booyah
    • ZippySLC's MAME Cab
« Reply #4 on: July 11, 2003, 12:06:58 am »
I had the same problem on mine. I'm using thermostat wire (20ga IIRC) and found that using a better crimper helped me out.
SirPeale
« Reply #5 on: July 11, 2003, 08:59:40 am »
I've used 22G wire with the blue ended connectors, and have had no problems whatsoever.  I've even given them the 'tug' test.
Previously, I had tried doing this with just a pair of pliers, with less than great results.  Ever since I started using a 'real' crimper (which came with a box of connectors I bought years ago) I've never had a problem.  I actually only started using the crimper just a little while ago, due to being really stiff.  A little WD-40 fixed that.
OSCAR
    • Oscar Controls
« Reply #6 on: July 11, 2003, 10:55:22 am »
The size of the barrel on disconnects varies a bit by manufacturer, I've noticed.  Since you had good luck with 16-14ga disconnects on 22ga wire, then I imagine that is more of the exception rather than the rule.  The manufacturer has recommended wire sizes for a reason, I suppose.  :)
SirPeale
« Reply #7 on: July 11, 2003, 11:05:39 am »
That, and I squash the $#!7 out of it, just to be sure.
Wade
  • Last login:December 01, 2025, 08:21:17 am
  • 80's Child
    • Wade's Gameroom
« Reply #8 on: July 11, 2003, 11:08:31 am »
Let's not forget that crimp connectors should only be used with stranded wire! Solid wire won't work reliably, don't bother with it.
Wade
dhansen
  • Last login:November 28, 2025, 10:41:14 am
  • No Quarters Needed
    • Arcade Stupidity
..as his cold lifeless fingers lie motionless on the garage floor, all he could hear in his head was...I JUST WANTED TO PLAY A GAME OF DONKEY KONG!!
