Author Topic: Electrohome G05-802 Monitor Troubleshooting...  (Read 2845 times)
« on: July 27, 2009, 12:39:37 pm »
I've got to get the right value fuses so I can replace some burnt out ones.  There is neck glow in the monitor.  This is a good sign, right?  8)
Kevin Mullins
    • Me on Myspace
Re: Electrohome G05-802 Monitor Troubleshooting...
« Reply #1 on: July 27, 2009, 02:07:25 pm »
Yes, neck glow is generally a good thing.  ;)
Are the fuses blowing still ?
« Reply #2 on: July 27, 2009, 02:42:53 pm »
I've still got to buy the right value fuses, so I'm not sure yet.  I did replace one blown one (5A) and now the spot killer LED lights up.  I have one more to replace (1A) I think, but I don't have any on hand.
Kevin Mullins
    • Me on Myspace
« Reply #3 on: July 27, 2009, 05:57:42 pm »
Just be sure to double check ALL transistors. I've personally never seen the chassis mounted fuses "just blow". There's usually a reason somewhere in that appropriate circuit. (X,Y, etc)
And of course check solder joints closely too while you're in there.
