Author Topic: help with a batch file in dos Working Now, Thanks  (Read 1935 times)
abispac
  • Last login:Yesterday at 12:30:42 am
« on: July 25, 2009, 01:52:44 pm »
Thanks for reading, im working an a new project i would like to use dos for faster boot time since is a dedicated game, i got everything setup , i just need help to set up a batch file that would call the game, so i dont have to use arcadeos or gamelauncher i want to boot staright of the game, heres what i got but it dosnt seem to work
autoexec
SMARTDRV.EXE /x
c:\sblive\liveinit.bat
c:\mame.bat
and bat file located at c:\
cd mame
mame.exe pacman
cd\
when i start the computer loads the drivers but ends up at c prompt it dosnt start the game, thanks for any help provided.
« Last Edit: July 25, 2009, 02:30:56 pm by abispac »
Beretta
Re: help with a batch file in dos
« Reply #1 on: July 25, 2009, 02:06:45 pm »
autoexec
SMARTDRV.EXE /x
c:\mame.bat
cd mame
mame.exe pacman
cd\
ok so i would assume that
cd mame
mame.exe pacman
cd\
is mame.bat? sitting in root of the drive "C:\mame.bat"?
ok so according to this your dos will start, get to mame.bat, run "C:\mame.bat"
at that point it will try to change to the directory "C:\mame"
is this the name of your mame folder?
it will then run mame.. what exactly is the name of your mame? and what version?
is it exactly "C:\mame\mame.exe"?
im guessing you have a spelling error in the bat.. go back and double check your directory and file names.
what exactly does it say when it tries to run?
if it  says "bad file or command" or something similar to that then you have a spelling error for sure.
if it says something else then you problably have a misconfiguratoin in your mame.
to make sure mame is'nt the problem you should try to run it manually and see if it loads up pacman.
abispac
« Reply #2 on: July 25, 2009, 02:09:57 pm »
i edited the batch file from some info i found here
@echo off
c:
cd mame
mame.exe pacman
 its seems to work in windows, ill give it a try in dos, thanks
