Author Topic: Arcade VGA worth it?  (Read 1830 times)
Rossman
  • Last login:July 20, 2010, 01:03:11 pm
« on: July 24, 2009, 01:33:51 am »
I have a computer monitor, a LCD, for my arcade screen, is it worth it to get an Arcade VGA video card, or should I just get a high end video card, considering that I will also be running games like Street Fighter 4 on it? Your thoughts?
Beretta
Re: Arcade VGA worth it?
« Reply #1 on: July 24, 2009, 01:37:17 am »
if your gonna use a LCD screen then there is no need for a arcadevga, it's only useful if you want to output to a older CRT arcade monitor.
Rossman
« Reply #2 on: July 24, 2009, 01:50:03 am »
Ah, I thought one of its features was to give a more arcade monitor type look when using computer monitors.
StephenH
  • Last login:January 09, 2023, 06:15:45 am
« Reply #3 on: July 27, 2009, 11:11:01 pm »
The ArcadeVGA card is mainly used for connecting a real arcade monitor which runs at 15Khz.   Most LCDs run at VGA/SVGA/XGA res (31-60Khz)  or higher and a standard video card works better for these.
