Author Topic: Is the octagonal restrictor on the Ultrastik 360 really tight to install?  (Read 909 times)
GaryMcT
  • Last login:September 24, 2014, 11:19:27 am
    • GaryMcT's arcade blog
Brought the U360 and the octagonal restrictor with me to work so that I could try it out during a break.  I didn't bring the shafts that came with it, and tried to use the ones from the circular/square restrictors.  Are they the same as the ones that came with the octagonal?  If so, it's a very tight fit.  Did anyone else run into this?
Gary
My blog on learning how to develop FPGA versions of arcade boards: http://garymct.blogspot.com
TheShanMan
    • My Arcade (updated 1/30/13)
I seem to recall posts here to that effect. I bet if you search on "octagonal" you can find some info on that problem.
GaryMcT
Ah ha! Thanks!
I think this is the one. . maybe I have it on backwards:
http://forum.arcadecontrols.com/index.php?topic=90389.msg949361#msg949361
