Author Topic: Super Sprint Monitor - cracked neckboard  (Read 1464 times)
ciaranmc10
  • Last login:July 30, 2009, 07:07:29 am
« on: July 21, 2009, 06:34:54 pm »
hi ppl,i am new to here,i ,like the person that started this thread also purchased super sprint 1986 atari arcade game.the back circuit board that is connected to the tube is cracked....is it possible to get another screen and connect the red 6 pin that comes from the bottom cabinet into the new monitor somehow are other??
« Last Edit: July 21, 2009, 07:54:28 pm by SirPeale »
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
Re: Super Sprint Monitor - cracked neckboard
« Reply #1 on: July 21, 2009, 07:55:58 pm »
You can probably repair the cracked neckboard.  Or if you don't think you can there are places that can do it for you.  That's assuming the neck of the tube isn't broken, if it is, you can kiss it goodbye and it will need to be replaced.
ciaranmc10
« Reply #2 on: July 24, 2009, 07:26:48 pm »
thanks for your reply.....when you say it it may need to be replaced ,how easy is it to get a new monitor?....the been at the end of the neck board look dodgey.....in desperate need of getting this working at :(
SirPeale
« Reply #3 on: July 25, 2009, 08:23:09 am »
I'd need a photo to give a good opinion.
Cracked neckboards are usually easy to repair if you can solder.  Cracked tube...first you have to find one, then swap it out...
jeremymtc
  • Last login:February 14, 2026, 05:36:37 am
« Reply #4 on: July 27, 2009, 02:50:04 am »
Ciaranmc, have a look at this: http://www.therealbobroberts.net/bnb.html
