Author Topic: Tron Upright Restoration - Monitor Question...  (Read 2016 times)
sihnstarr
  • Last login:December 08, 2011, 12:48:56 pm
« on: July 21, 2009, 01:36:41 pm »
Greetings Programs!
You may have seen my post on my Sinistar Cockpit. Well, my Tron Upright is having problems in the monitor department too.
When I power up the machine, the picture has waves running through it. Now, I sent the monitor chassis and the entire board set to Eldorado Games to be worked on. They could not find anything wrong with the monitor chassis. There were a couple of issues with the board set which they fixed and then sent everything back to me.
So, I hook everything back up, monitor is still wavy. The only thing that I did not send to them was the unit in the bottom of the cabinet that has the big capacitors and bridge on it. I checked this for voltages and from what I have in my manual and what I have found online, the voltages from it are correct and steady.
So, my question is, is this some kind of grounding problem? Or is it something else in the cabinet that I have overlooked?
Thank you in advance,
Sihn Starr Rossi
WunderCade
Re: Tron Upright Restoration - Monitor Question...
« Reply #1 on: August 30, 2009, 12:55:54 pm »
The waves are usually a grounding/fuse block/edge connector problem.  Bob Robert's site has a tech article on it.
Any BEFORE pics for this Tron restoration thread?
« Last Edit: August 30, 2009, 01:00:24 pm by WunderCade »
shred5
  • Last login:July 25, 2013, 04:37:40 pm
« Reply #2 on: September 09, 2009, 03:35:58 pm »
Level42
« Reply #3 on: September 09, 2009, 05:43:14 pm »
I see you're new here, but we have a separate monitor section.
