Author Topic: Need help mounting a monitor in my first cabinet  (Read 1213 times)
Nick Rocco
  • Last login:July 09, 2013, 10:23:54 pm
« on: July 15, 2009, 07:54:52 pm »
I am planning to build a cocktail cabinet with some plans that I found from Kyle Lindstrom on arcadecontrols.com.
I am not sure how to mount my monitor and give it that nice finished look.
I have a 21" crt computer monitor that I think I need a mounting bracket for.  What king of bracket do I need and how can I get one?
Also, on most cocktails that I have seen it looks like there is some kind of frame under the glass to give it a nice finished look.  When I see a monitor mounted in a bracket (not in a cabinet) it has no frame.  Where can I get the frame and how do I know it will fit my monitor.
Thanks in advance for any help!
NR
Re: Need help mounting a monitor in my first cabinet
« Reply #1 on: July 15, 2009, 08:27:13 pm »
Those frames you see are usually on actual arcade monitors.  Are you going to decade the computer monitor?  If I were you I'd just support it from underneath.  Build a box for the computer components and then put the back of the monitor on top of the box and line everything up.
The frame you are referring to is a bezel.  They can be bought in all different shapes and sizes.  Check out Happ (but order from somewhere else):
http://www.happcontrols.com/monitors/monitors_curved_bezels.htm
http://www.happcontrols.com/monitors/monitors_flat_bezels.htm
http://www.happcontrols.com/monitors/49028800.htm
http://www.happcontrols.com/monitors/49074100.htm
