Author Topic: I could use a little Donkey Kong help (or suggestions)  (Read 975 times)
  • Last login:Yesterday at 02:13:29 pm
« on: July 15, 2009, 01:59:03 pm »
What was used on an original cabinet to cover the piece of wood where the instruction sticker goes and that also holds the bottom bezel in place?  The cabinet I have (see pic) is bare wood which is obviously not right - what goes over it?  Laminate?  Vinyl?  Paint?  Something else?  I'd appreciate some suggestions...
Bender
Re: I could use a little Donkey Kong help (or suggestions)
« Reply #1 on: July 15, 2009, 02:33:26 pm »
Laminate
wilsonart 1560 (matt black) is perfect match
PM me I have some scraps that should be enough to cover that
the top piece was missing on mine, I replaced it with that laminate and you can't tell the difference between that and the front piece
« Reply #2 on: July 15, 2009, 02:56:56 pm »
Thanks Bender - with all the help you've given me on this maybe you should just come down to NJ and finish up the cab for me!  I have some ABS plastic laminate left over from the control panel that I could use but thanks for the offer.   Are you saying that there was also a piece of laminate on top of the wood too?  What about the groove for the bezel?
After thinking about this for a while I may end up just painting it - the rustoleum semi-gloss I used for the inside edges is great stuff - it dries nice and flat and covers great.  I don't know...
Bender
« Reply #3 on: July 15, 2009, 06:57:13 pm »
originaly it must have been laminated then the grove cut right through the laminate
When I redid mine I painted the little bit behind the groove cause it wasn't going to be seen and just laminated the little part inftont of the groove
I'm glad I can help and really I don't mind or I wouldn't have offered
good luck, It's looking amazing so far :cheers:
I've had good luck with krylon Semi-flat (rust proof or something like that) it matches the laminate pretty well and judging by you other projects you know how to do the paint right!
« Last Edit: July 15, 2009, 07:00:12 pm by Bender »
