Author Topic: hooking up Vision Pro monitor to Jamma harness  (Read 1084 times)
bdsjake
  • Last login:September 18, 2017, 12:08:23 am
  • livefree
« on: July 13, 2009, 07:51:21 pm »
Hi all, here is my summer project:  built a mame cab a few years ago with ArcadeVGA and standard resolution monitor.  It is a Vision Pro MTG1901CM (I think, a little hard to read w/o pulling it out of the cab).  So, hard drive fail and I decide to try a 48-in-1 board rather than building or buying or fixing the computer.
The monitor has a 6 pin molex type connector going to it (which I had wired to the ArcadeVGA), the wiring harness I bought (from jammaboards.com), if I have it figured out right, has only a 5 pin connector of a different type.
I am guessing the 5 pin combines Horz and Vert sync?
what would be the best way to connect this up?  get a new wiring harness?  cut and splice the wires together?
any ideas are appreciated, thanks!
« Last Edit: July 13, 2009, 08:08:27 pm by bdsjake »
