Author Topic: Trying to figure out multisystem setup  (Read 1319 times)
xxkodemanxx
  • Last login:August 18, 2012, 12:50:47 pm
« on: July 09, 2009, 02:41:39 am »
Alright so. I have my Mame cap up and running.
using a Neotec Arcade Monitor
and i-pac keyboard encoder.
what I would like to do is add a dreamcast into the mix.
I want to know the best way to have it switch from Mame to Dreamcast with a switch flip..
I know this is possible using something like this...
http://www.trianglecables.com/4waydb9mansw.html
but thats using serial cable..
So tell me if im wrong...
For the controls I need to run my i-pac into this..
http://shopper.cnet.com/input-cables/mouse-adapter-ps2-to/4014-6595_9-2847503.html
then into a switchbox that also has a dreamcast serial adapter plugged into it on another slot position.
then i need a Second Switchbox for changing the system.
that has the vga from the arcade monitor in one slot.
and the dreamcast with a vga adapter in another slot on the switchbox
this sound right?
2 switch boxes..one for the controls
and one for the system?
i know i could just use the dreamcast emulator..
but it doesnt run 100%..maybe like 95%..and I KNOW that difference..haha
thanks guys
thomascirca
  • Last login:December 07, 2011, 08:36:44 pm
Re: Trying to figure out multisystem setup
« Reply #1 on: July 10, 2009, 12:55:28 pm »
I'm adding a Dreamcast into my arcade cabinet as well. What I recommend doing is wiring everything up to DB25 connectors and then using a switchbox like the one you've got pictured to switch between the two.
I recommend looking at this project log here:
http://www.dragonslairfans.com/smfor/index.php?topic=6.30
I think it basically covers what you're looking to do.
