Author Topic: Which emulator is better for SNES??? ZSNES or SnesX  (Read 2161 times)
Gavica
  • Last login:March 05, 2011, 09:56:15 am
« on: July 07, 2009, 06:01:10 pm »
which is better?
TeutonicDarkness
  • Last login:July 16, 2019, 10:54:16 pm
Re: Which emulator is better for SNES??? ZSNES or SnesX
« Reply #1 on: July 07, 2009, 07:08:05 pm »
 I would defiantly say Znes without a doubt.
during some games choppiness is noticable in Snesx
also znes is much easier to set up with a front end!
 * However I have noticed a few games (only a few)
are unplayable on Znes... I remember a Yoshi/Mario game
for sure... Can't remember the name.
 might actually run both if you just must have all games playable.
Hope this helps...
Gavica
« Reply #2 on: July 07, 2009, 07:13:21 pm »
under video what settings have u picked for optimal performance?
TeutonicDarkness
« Reply #3 on: July 08, 2009, 10:57:42 pm »
Actually I don't think I had to change anything.
As far as I can tell everything is still at default setting.
kagaden
  • Last login:September 10, 2022, 10:58:37 pm
« Reply #4 on: July 09, 2009, 01:28:38 am »
Zsnes for the win.
The only reason Snes9x is popular from what I've seen is due to the ability to port it to different platforms. If you're on the PC, you want Zsnes.
Sosetsuken
  • Last login:November 10, 2014, 02:13:46 pm
  • Da Daaah Da Daaah Da, Da Da Daaah Da
« Reply #5 on: July 09, 2009, 05:03:36 am »
SNESGT > All
Most accurate and cab friendly!
Ginsu Victim
  • Comanche, OK -- USA
« Reply #6 on: July 09, 2009, 08:33:07 am »
SNESGT? WTF is that?
I've never had a single problem with ZSNES. I've been using it since the very first release.
Edit:
However, after reading a little about SNESGT, I think I'm going to try it out.
« Last Edit: July 09, 2009, 08:35:16 am by Ginsu Victim »
atomikbohm
  • Last login:January 22, 2018, 11:33:35 am
« Reply #7 on: July 13, 2009, 05:21:34 pm »
What OS are you guys using?  I'm setting up a cab with vista 64bit and don't remember if any of these emulators work with vista.
