Author Topic: does anyone know what television tubes will interchange with a WG U2000?  (Read 1323 times)
mvsfan
  • Last login:May 26, 2016, 08:05:26 pm
the topic says it all. ive got a 25" U2000 series monitor with a bad tube and ive got plenty of CRT Tvs sitting around since they slowly got replaced over a few years with HDTVs.
i know that a lot of the CRTs are interchangable i just dont know wich ones.
Kevin Mullins
    • Me on Myspace
Pretty much anything with the same first three digits of the tube number such as A63xxxxx.
As long as that number, the pin count and size on the neck are the same you should be in there.
