Author Topic: Problems with CPS-2 and Neo Geo roms  (Read 1151 times)
Jop
  • Last login:April 03, 2011, 04:20:24 am
« on: July 06, 2009, 06:22:22 pm »
I'm having problems running CPS-2 and Neo Geo roms... the problem being they don't work.
I'm running MAME 0.106 and using the 0.132 romset rollbacked using clrmamepro.
All running on a 1.6ghz P4, 383mg ram, win xp using MALA 1.5 as a front end.
Any idea what I'm doing wrong?
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: Problems with CPS-2 and Neo Geo roms
« Reply #1 on: July 07, 2009, 02:41:13 pm »
... the problem being they don't work....
Err.... What do you mean "don't work"?  Any error messages, or symptoms?  Could you run mame from the command line (to see if it's mala, or see mame's error messages if any).
Otherwise it could be anything from mame (or mala) is not setup correctly, to your computer is broken.
Robin
Knowledge is Power
abispac
  • Last login:Yesterday at 07:58:36 pm
« Reply #2 on: July 08, 2009, 01:41:58 am »
do you have the bios sets in the roms folder? example neogeo.zip , you need that to run neogeo games...
