Author Topic: pSX Emulator & Ultimarc UltraStik 360  (Read 1563 times)
moonchilddave
  • Last login:May 17, 2021, 01:21:04 pm
« on: July 06, 2009, 05:49:58 pm »
I was looking to add a Playstation emulator on my cabinet, and decided to give pSX a try due to the recommendation of http://nonmess.retrogames.com/
I got it all set up and running and even loaded a CD image I made, and it seems to work just fine.  The only problem I have is I can't seem to get it working with my joystick and buttons.  I'm running an Ultimarc UltraStik 360 with input mode and have it wired to 6 buttons plus P1 & P2 start.
Has anyone managed to get pSX running with this setup?  Or could someone recommend another Playstation emulator that works with this stick?
nukedawg
  • Last login:May 08, 2021, 10:25:12 am
Re: pSX Emulator & Ultimarc UltraStik 360
« Reply #1 on: July 07, 2009, 04:00:27 am »
I use epsxe 1.7.0 with my 2 U360's and they work like a charm, although I use a minipac for my buttons
Visitor Q
  • Last login:May 01, 2019, 09:09:30 am
  • The Saw Is Family
« Reply #2 on: July 07, 2009, 08:12:22 am »
I use epsxe as well and my buttons are key strokes, works fine here as well.
“Woe be unto him who opens one of the seven gateways to hell, because through that gateway evil will invade the world."
moonchilddave
« Reply #3 on: July 07, 2009, 02:15:37 pm »
Actually, pSX works fine.... turns out that the USB cable for my stick came loose...  :banghead:
Ginsu Victim
  • Comanche, OK -- USA
« Reply #4 on: July 07, 2009, 02:41:22 pm »
I was about to say, pSX should work fine. I use it with my U360s and love it.
moonchilddave
« Reply #5 on: July 07, 2009, 05:12:04 pm »
Do you have your stick set up in input mode with the buttons?  If so, how do you configure it so that a button sends the escape key to exit the emulator?  Unfortunantly you can't change the key for quit in pSX - at least from what I can tell.
Ginsu Victim
« Reply #6 on: July 07, 2009, 05:16:10 pm »
I use a minipac for the buttons. Sorry.
