Author Topic: Coin box dimension question  (Read 1624 times)
iscariot
  • Last login:April 02, 2025, 12:44:33 am
« on: July 06, 2009, 11:09:24 am »
Hey all.  I'm looking for something to use as a coin box in my cab.  The pics are here on the site.  I was hoping someone could recommend a container that I can take out through the bottom coin door.
Re: Coin box dimension question
« Reply #1 on: July 06, 2009, 11:27:08 am »
I used the bottom 1/3 of a box of wheat thins or something wrapped in duct tape.  It works great.
iscariot
« Reply #2 on: July 06, 2009, 11:34:51 am »
I was hoping for something a little more substantial than that if possible, maybe metal, wood or plastic.
« Reply #3 on: July 06, 2009, 11:49:42 am »
measure it then find  something in the tupperware section of walmart that fits?
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #4 on: July 06, 2009, 12:02:56 pm »
Well, I don't have the inclination right now to search to see what you are using as a coin door and how you have mounted it.
If you make cross-link the pictures to this thread, people will have an easier time making recommendations.
« Last Edit: July 06, 2009, 12:25:43 pm by CheffoJeffo »
Working: Not Enough
Projects: Too Many
Progress: None
Ginsu Victim
  • Comanche, OK -- USA
« Reply #5 on: July 06, 2009, 12:09:35 pm »
I'm just using a tupperware-style bowl. Works great.
I hear ya. How hard is it to post a link? I haven't bothered looking.
« Last Edit: July 06, 2009, 12:12:02 pm by Ginsu Victim »
CheffoJeffo
« Reply #6 on: July 06, 2009, 12:20:45 pm »
True ... if it's a Midway-style door, then there are lots of options. If it is an over-under door, then there are obvious options. It all depends and specifics makes it easier for people to provide quality advice.
Working: Not Enough
Projects: Too Many
Progress: None
iscariot
« Reply #7 on: July 06, 2009, 01:02:40 pm »
It's an over/under.  Here's the pic of the cutout.
CheffoJeffo
« Reply #8 on: July 06, 2009, 01:40:10 pm »
OK, in absence of seeing whether or not the door has the enclosure built-in or not (indeed, if it is a CoinCo or Happ door and whether or not you have an enclosure), I would suggest a simple bread pan as it will fit in the bottom of the cab or likely inside the enclosure.
Or, the appropriate coin box for the door is always a good choice.  ;)
Working: Not Enough
Projects: Too Many
Progress: None
