Author Topic: Kortek KTX26 - Sync Drift  (Read 1817 times)
DarkSide
  • Last login:August 03, 2023, 05:15:13 pm
« on: July 02, 2009, 11:15:44 am »
Hi guys, just started a new project with a Sega Rally sitdown cab, and a Kortek KTX26 Chassis.
Everything is working just fine, except that i cant get a stable sync lock on the kortek chassis, after around 10 secs  the picture starts to roll, and it takes a good deal of fiddling with a V-Hold pot to get it stable again.
Didn't do a cap kit yet on the chassis, it would be nice getting that sync drift fixed first :)
Any ideas ?
Regards
Ronni
gokun
  • Last login:March 26, 2014, 04:57:18 pm
Re: Kortek KTX26 - Sync Drift
« Reply #1 on: July 02, 2009, 12:46:03 pm »
this may sound silly....but try letting it warm up  first before you adjust the hold...
give it like 5-10min then adjust it and see if it holds...just something easy to try....no promises. ;)
DarkSide
« Reply #2 on: July 02, 2009, 12:47:30 pm »
Already tried that.
But thanks for the suggestion :)
DarkSide
« Reply #3 on: July 02, 2009, 05:29:41 pm »
Fixed, a 5kohm resistor between vertical sync and video ground fixed the problem :)
