Author Topic: Umk3 help  (Read 1474 times)
djbubba2002
  • Last login:April 09, 2010, 01:19:31 pm
Umk3 help
« on: July 01, 2009, 01:57:39 pm »
I just got a umk3 cabinet and jamma board ,. when  turn it on ..
I want to know if there are setting , i can chagne..is there setting i can get in to ..
I cant fine the buttom in the cabinet to get tot eh setting
can you tell me how to get in them ..thanks
« Last Edit: July 01, 2009, 03:42:45 pm by djbubba2002 »
Re: Umk3 help
« Reply #1 on: July 01, 2009, 03:56:07 pm »
dipswitch 8 row 2 will open the test menu, if its a dedicated MK3/MKII then there is a test switch inside the door.
this should go in the MAIN section, not here
« Last Edit: July 01, 2009, 04:08:55 pm by Malenko »
djbubba2002
Re: Umk3 help
« Reply #2 on: July 01, 2009, 04:47:11 pm »
I dont see no switch in the door... can i turn it on somewhere ..i see two red with 8 white little things ..hehhehe.. can i turn it on from there ..
Re: Umk3 help
« Reply #3 on: July 01, 2009, 06:10:01 pm »
if you dont have a test mode switch, you have to use the dipswitch, its the only way
