Author Topic: Operation Thunderbolt - What type of monitor?  (Read 3149 times)
Flake
  • Last login:January 11, 2025, 01:16:20 pm
  • I am Evil Homer....I am Evil Homer....
« on: July 01, 2009, 09:29:49 am »
klov.com says it uses a 19" WG mirrored-in standard resolution, raster monitor.  I guess my only question is - what is a mirrored in monitor?  Is this just a regular 19" WG monitor?
I'm asking because there is a Operation Thunderbolt for sale in my area but seller says it probably needs a new monitor.
SirPeale
  • Green Mountain Man
Re: Operation Thunderbolt - What type of monitor?
« Reply #1 on: July 01, 2009, 10:41:23 am »
It's a monitor that reflects off a mirror to give a specific effect.  Space Invaders is an example.  So is Terminator 2.
And just because a seller says it needs a new monitor doesn't make it so, it probably just needs repair.  Few monitors are so far gone they need replacement.
Flake
« Reply #2 on: July 01, 2009, 10:43:03 am »
But the actual monitor itself is simply a 19" standard res, raster monitor then?
I'm just trying to get an idea of "worst-case" scenario total cost for this game.
Flake
« Reply #3 on: July 01, 2009, 11:04:28 am »
OK I just talked to the seller and he has fessed up to the issues:
1.  Sound - he says it skips around.  Not sure how to fix - any thoughts?
2.  Monitor - there are lines running across monitor and the tint seems off.  Does it just need a cap kit maybe?
SirPeale
« Reply #4 on: July 01, 2009, 11:20:51 am »
Impossible to tell.  Lines across monitor could be screen voltage turned up too high or a shorted transistor or board faults.  Sound faults sound like board problems.
Since it clearly has issues, I'd offer a fairly low amount.  How much is he asking?
And it's a big cab too.  http://jhanson.com/images/pictures/arcade/thunderbolt/thunderbolt.png
Flake
« Reply #5 on: July 01, 2009, 11:22:14 am »
I can get it for $100.  Its probably worth that I would think.
Flake
« Reply #6 on: July 01, 2009, 11:58:46 am »
OK now he says the monitor shows up green?
Sosetsuken
  • Last login:November 10, 2014, 02:13:46 pm
  • Da Daaah Da Daaah Da, Da Da Daaah Da
« Reply #7 on: July 01, 2009, 09:15:42 pm »
Is the monitor changing like this every turn on, or is the guy lying?
