Author Topic: Very New Arcade enthusiast looking for help with WG19K7602  (Read 1189 times)
midnightpulp
  • Last login:September 03, 2014, 11:48:19 pm
« on: June 26, 2009, 06:54:20 am »
Hey all,
(Thanks to SirPeale for the answer to my initial question).
Just picked up an Neo Geo 2 slot with a Wells Gardner 19K7602. The screen has some burn in but still looks good. Just yesterday, the picture starting to contract and expand intermittenly and flicker. Tried everything: Cleaning the games, took out the marquee lights, made sure there were no electric devices on while I was playing. No luck. The monitor's board is caked with dust and I'm sure the main PCB could use a good cleaning. Just crossing my fingers that nothing is wrong with the monitor itself.
Any ideas and help would be greatly appreciated.
« Last Edit: June 26, 2009, 11:06:08 pm by midnightpulp »
SirPeale
  • Green Mountain Man
Re: Very New Arcade enthusiast looking for help with WG19K7602
« Reply #1 on: June 26, 2009, 08:20:00 am »
If the unit isn't on when you're adjusting, how will you know when you've made the proper adjustment?
Yes, on is fine.  Preferable, even.
midnightpulp
« Reply #2 on: June 26, 2009, 11:01:29 pm »
Thanks. Just needed the reassurance from someone who actually knows what they're doing.
Flickering problem still isn't solved, however. The monitor's board is caked with dust. If it's not a problem with the monitor, I wonder if that could be causing the problem?
