Author Topic: Video HELP on candy MAME cab  (Read 2708 times)
candycabguy
  • Last login:December 27, 2009, 12:47:10 pm
« on: June 23, 2009, 02:15:06 pm »
running:  P4 2.3, 1 GIG RAM, XPPro, Nvidia 256 MB (7600?) VC, soft15, Neo Geo 29" candy cab, Hitachi monitor
MAME: v .126
SYMPTOM: some horizontal-type scanlines in video processing, not HORRIBLE, but enough to distract, almost seems to be a slow refresh rate or something, appears as video 'lag' when action gets fast.
Wanted to post here before I go tweaking everything, including, MAME settings, video card driver, etc.
Best opinions?  Whats likely the culprit?  Was going to start with fiddling with refresh rate settings for monitor in Windows.
THANK YOU, any help greatly appreciated!
Lee
  • Last login:January 30, 2026, 04:39:53 pm
Re: Video HELP on candy MAME cab
« Reply #1 on: June 23, 2009, 02:21:59 pm »
Do you have tripplebuffer on in MAME?
candycabguy
« Reply #2 on: June 23, 2009, 03:56:07 pm »
Nope, tripplebuffer disabled, should I enable?
ALSO - running at 800 X 600, & in Windows the screen 'dances' a bit at that resolution, is that normal?  Should I bump resolution down?
BTW using Arcade Maximus frontend here
# FULL SCREEN OPTIONS
triplebuffer              0
switchres                0
full_screen_brightness    1.0
full_screen_contrast      1.0
full_screen_gamma         1.0
# WINDOWS VIDEO OPTIONS
video                     ddraw
numscreens                1
window                    0
maximize                  1
keepaspect                1
prescale                  1
effect                    none
waitvsync                 0
syncrefresh               0
# DIRECTDRAW-SPECIFIC OPTIONS
hwstretch                 1
# CORE PERFORMANCE OPTIONS
autoframeskip             0
frameskip                 0
seconds_to_run            0
throttle                  1
sleep                     1
speed                     1.0
refreshspeed              0
« Last Edit: June 23, 2009, 03:59:12 pm by candycabguy »
« Reply #3 on: June 23, 2009, 04:12:15 pm »
Turn tripplebuffer on and see what that does for you.
candycabguy
« Reply #4 on: June 23, 2009, 04:45:09 pm »
triplebuffer - helps on lower sys requirement games, but I get 'draggy', jerky audio on Neo Fighters, etc.
Opinions?
« Reply #5 on: June 23, 2009, 04:47:14 pm »
You may want to try an earlier version of MAME as well...
candycabguy
« Reply #6 on: June 23, 2009, 04:50:38 pm »
I was considering trying to go to TinyXP, & perhaps upping my processor to a 3 Ghz Prescott, would that run smoother with .126?
« Reply #7 on: June 23, 2009, 05:36:08 pm »
It's possible.  You may want to upgrade your ram as well.
Ummon
  • Trade Count: (+13)
« Reply #8 on: June 24, 2009, 01:55:14 pm »
What are these lines you're talking about?  Pictures......
Yo. Chocolate.
Stephen Hawking
Zebidee
  • Last login:January 31, 2026, 11:25:34 pm
« Reply #9 on: June 29, 2009, 03:35:42 am »
I think your problem is horizontal tearing. Triplebuffer=1 works great for some games that suffer tearing (especially horizontally scrolling games like Wonderboy and Cadillacs and Dinosaurs), but causes other problems (e.g. choppy sound) in other games. You have to apply it on a case-by-case basis, not just as an all-or-nothing.
Ummon
« Reply #10 on: June 30, 2009, 06:33:28 pm »
The mame32 help file advises using 'match game refresh' with triplebuffer. If you're using Mame after the video re-write, never mind.
Yo. Chocolate.
Stephen Hawking
