Author Topic: lag in virtuaNES, FCEu, etc.????  (Read 5755 times)
hulkster
  • Last login:September 05, 2021, 04:27:59 pm
  • HulkaMAMEia is runnin' wild!
« on: July 08, 2003, 12:22:58 am »
yup, i have lag on my nes games!!!  what the hell.  its not my computer being slow cuz i can play games like neverwinter nights and mohaa on it, so whats the problem?  my zsnes runs fine, as does mame, but for some reason the nes ones are lagging!  whats the problem?  oh and i run all my emu's through mamewah.
Syxx
  • Last login:June 25, 2006, 06:36:25 pm
  • Bling Bling
Re:lag in virtuaNES, FCEu, etc.????
« Reply #1 on: July 08, 2003, 12:37:15 am »
try nester thats what i use, or ROCKNES and Nesticles also worth trying. i only use
nester caz its the only one that seems to work right with MAMEWAH Front End for me.
hulkster
« Reply #2 on: July 08, 2003, 12:50:55 am »
well that didnt exactly work all that great.  i had some problems with it, plus i couldnt push escape to go from the emu back to mamewah.  anybody help me with this?
hulkster
« Reply #3 on: July 09, 2003, 02:20:03 pm »
bumping this cuz i want to play nes games on mamewah
hulkster
« Reply #4 on: July 09, 2003, 09:52:32 pm »
anybody?
stuzza
  • Last login:May 13, 2025, 09:19:19 pm
    • ScreenshotArchive
« Reply #5 on: July 10, 2003, 06:31:35 am »
Have you tried FCE Ultra yet?  That's what I run through Mamewah with no problems.
Luxury
  • Last login:November 18, 2006, 01:21:59 pm
  • Unfortunately It's True. :(
    • arcadeZERO
« Reply #6 on: July 21, 2003, 02:55:24 pm »
i have the same sort of problem.  but with nesticle, nester, and (this is a killer) visual boy advance.  but NOT for gba games(these work perfect)....only gbc games!  what gives?!  not really lag either...its EXTREME lag.  i push a button, and character jumps 3 minutes later.
i will try fce ultra out.  but any thoughts on the gbc games?
Ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn.
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
« Reply #7 on: July 21, 2003, 04:44:39 pm »
I love FCEU.  It plays really well.  I tried RockNES, and found that I couldn't adjust a lot of settings that I really needed with FCEU.
That being said, I'm putting together a console PC to hook up to my TV.  The frontend is GameLauncher.  It works really great - on the monitor.  When I move it to the TV, I can only get Stella and ZSNES to display properly.  FCEU won't display properly at all.  1/2 the reason I built this was for NES games!  RockNES, OTOH, displays okay, but not well.
TalkingOctopus
  • Last login:August 04, 2025, 03:48:02 am
    • My Arcade
« Reply #8 on: July 21, 2003, 10:49:42 pm »
What are your specs?  I have an athlon xp 1800 w/ 512 ram and virtuanes runs and looks great.  It often makes no sense how much resources an emulator uses...didn't the original nintendo have under 2 mhz and the super nes have under 4 mhz?
Nesticle, although outdated, can run nes on any computer, slow or fast.
hulkster
« Reply #9 on: July 22, 2003, 04:03:35 pm »
well just so you guys know, im using virutalNES now.  it allows you to map your controls so i like it better.  fceu was great for windows only, but now that im trying to config all this crap, virtualNES seems to work the best.  oh and by the way, if you are trying to install virtualNES and are having trouble running it, make sure you have your CD ROM drive plugged in and working along with the sound plug plugged into your mobo or sound card connecting to your CD ROM drive.  for some reason it has to have sound before it can start!  just a personal tip :)
Jakobud
  • Last login:December 23, 2025, 02:48:26 am
« Reply #10 on: July 22, 2003, 06:16:39 pm »
Well Hulk, do you get the same lag/bad performance from VirtuaNes when you just run it without going through Mamewah?
hulkster
« Reply #11 on: July 22, 2003, 08:40:24 pm »
well i switched to virutalNES and no lag at all.  but i also switched machines and didnt try fceu either.  so i dont know
