Author Topic: Dirt Behind LCD Screen  (Read 2234 times)
  • Last login:Today at 04:55:22 pm
« on: June 22, 2009, 08:52:54 pm »
Anyone ever seen this before?  I just bought an LCD computer monitor off eBay to use in a cab and it appears like there is a lot of dirt behind the screen.  Any ideas on what to do??
grantspain
Re: Dirt Behind LCD Screen
« Reply #1 on: June 23, 2009, 03:07:00 am »
does it look like a cloudy smudge although you can see the picture through it?
Blanka
« Reply #2 on: June 23, 2009, 07:22:40 am »
24 inch iMacs suffer from this. They have some coating letting loose. Nothing to do about that.
Most common though is that bugs/dust/worms/fungus gets inside the screen through the heat vent slots on the back. Nothing much to do about that either. You can disassemble and clean the thing, but I wonder if it is an easy job.
« Reply #3 on: June 23, 2009, 07:42:43 am »
Here are some pictures:
Ginsu Victim
  • Comanche, OK -- USA
« Reply #4 on: June 23, 2009, 10:32:03 am »
Did you buy it knowing this? If not, you should complain.
« Reply #5 on: June 23, 2009, 10:41:09 am »
No I did not.  I have complained.  We'll see what happens there.
The crappy thing is that this would be a great monitor for my project minus the dust behind the screen.  No dead pixels, great viewing angles, etc...
Is it even possible to get the front off to clean behind there?
dmbj
  • Last login:March 08, 2011, 12:54:43 pm
« Reply #6 on: June 24, 2009, 02:24:14 pm »
Yes you can get to it.  take apart the calm shell case, remove the back metal protector over the circit boards, remove the boards, remove the metal shroud holding the lcd panel to the back lite. Discard all that tape, you dont need it.  remove lcd from backlite, clean back of lcd panel and front of back lite panel.
While you are in there replace the 2-5 caps on the secondary side of the power supply, often 470uf 25v or so. (sometimes 820uf)  get good ones.  Panasonic cf series are very good, low esr electolitical caps.
