Author Topic: WG U2000 flickering brightness/contrast fault  (Read 1514 times)
Greylights
  • Newbie
  • Last login:June 22, 2009, 01:00:35 pm
« on: June 22, 2009, 12:58:17 pm »
Hi,
I'm currently working on a Mame cabinet project, and so far by searching these and other forums I've been able to solve all the problems I've met. A fault with my monitor has occurred however and I cannot find any similar problems reported.
I'm using a WG U2000 monitor, UK electrical standards.
I linked the monitor to a PC (using a VGA breakout cable and Soft15kHz), and for several weeks I was getting a great picture and everything was fine.
A few days ago, as I was playing, the screen flickered and became dim and dark. The picture is still stable, crisp and sharp, but the colour is entirely washed out.
Adjusting the drives/bias does not resolve this.  Every so often, as I touch the neckboard, the screen flickers back to normal, but then goes bad again straight away.
Is this problem pathognomonic of a well-known issue? Is a cap kit likely to solve it?
Many thanks, any advice appreciated.
(BTW I'm a newb, totally inexperienced, learning as I go. Apologies if I don't understand something obvious.)
Kevin Mullins
    • Me on Myspace
Re: WG U2000 flickering brightness/contrast fault
« Reply #1 on: June 22, 2009, 01:08:09 pm »
Since you noted that touching the neckboard had an effect on the screen, I would start there.
Check it closely for bad solder joints especially on larger components, like possibly a resistor for the screen voltage.
