Author Topic: My second Cab attempt, semi slim (upd 8/5 .... marquee)  (Read 16005 times)
mj147
  • Last login:November 10, 2024, 08:04:14 pm
« on: June 21, 2009, 10:00:42 pm »
OK folks its been a while since my last build. Built   this lil guy back in 05 and hes a bit lonely  ;)
I now have a garage and a few more tools at my disposal this time around.  This guys shape is heavily inspired by Martijn's SF cab  and Valiant's Build .
Progress  will be slow as parts trickle in,  I have yet to find online shops with Sanwa or Seimitsu joys without a long delay on ship dates  :dunno
Lemme know what you folks think , all comments appreciated  :P
mj147
« Last Edit: August 05, 2009, 04:46:21 pm by mj147 »
mj147
Re: My second Cab attempt, semi slim
« Reply #1 on: June 21, 2009, 10:08:00 pm »
I will be using a 22" lcd so I was able to go slim ish :)
Cut one side out and just used a pattern bit to trace the other.
mj147
mj147
« Reply #2 on: June 21, 2009, 10:15:07 pm »
Just added some support rails
Still experimenting with uploading pics, I guess my earlier attempts gave me file too big errors :dunno
mj147
mj147
« Reply #3 on: June 21, 2009, 10:35:07 pm »
Glued and screwed some 3" casters
m147
mj147
« Reply #4 on: June 22, 2009, 06:55:04 pm »
Just a few more pics
mj147
mj147
« Reply #5 on: June 22, 2009, 06:56:55 pm »
mj147
« Reply #6 on: June 22, 2009, 06:58:18 pm »
last one for today :)
mj147
Gatsu
« Reply #7 on: June 22, 2009, 10:57:08 pm »
lookin good. what kind of art theme are you going with?
mj147
« Reply #8 on: June 22, 2009, 11:12:21 pm »
Undesided on a theme or name for the cab  ;D
More than likely go the black cab blue t mold route and some matching cp and marquee.
Still a few things to work out, just not trying to rush things
mj147
mj147
« Reply #9 on: June 23, 2009, 10:00:06 pm »
Two more for the log,
Cut out bottom of marquee bezel and control panel. They are "rough" at the moment.  The cp will have the corners rounded and the back beveled  (not sure the proper term) to fit flush against the bezel.
Lemme know what ya guys think so far.
mj147
mj147
« Reply #10 on: June 23, 2009, 10:01:05 pm »
Second pic;
  • Last login:Yesterday at 06:49:16 pm
« Reply #11 on: June 24, 2009, 09:48:12 am »
Looks good....  these slim cabs are starting to grow on me.
Gatsu
« Reply #12 on: June 24, 2009, 11:09:40 am »
damn thats lookin nice. can't wait to see it finished.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #13 on: June 24, 2009, 01:15:17 pm »
Looks nice. Are you going to hinge that control panel?
NO MORE!!
mj147
« Reply #14 on: June 24, 2009, 02:29:56 pm »
Was hopping I can make it swing back, pivot from the front of the control panel. Currently looking up what others have used in the past. I'm leaning towards a hidden , no gap type of hinge.... any suggestions?
mj147
PeteDiak
  • Last login:December 09, 2012, 10:02:42 pm
    • minimulti game
« Reply #15 on: June 24, 2009, 08:08:57 pm »
Wow looks great.. take your time and you will be happy with the end results. What are the benefits of a "slim" cab?
Projects
Miss Pac Man Cocktail (Finished)
Mini Multi Game (Finished)
RayB
  • There's my post
    • RayB.com
« Reply #16 on: June 25, 2009, 11:55:22 am »
I don't have any suggestions as to what's best. A front or back-mounted piano hinge might be most stable for that size, but then the panel won't be removable to be taken to a work bench. For that, you either go with the standard "clamps" (which if are not mounted perfectly might end up with some "play" and vibration), or you can bolt with easily removable wing-nuts (but I find that one annoying, as it takes time to unscrew wing-nuts whenever you need to get in and fix something).
Keep in mind that clamps or wingnut solution assumes your design will have room for you to reach in with your arm.
NO MORE!!
mj147
« Reply #17 on: June 25, 2009, 02:48:01 pm »
I would say weight,  lcd panels hardly weigh(sp?) anything, allowing to get away with out having to build a frame around a crt . Also  not having a tube you dont have to  build a deep cab ( both a size and weight saver)
mj147
« Last Edit: July 01, 2009, 06:17:47 pm by mj147 »
mj147
« Reply #18 on: June 26, 2009, 09:20:58 pm »
Slow going the last few days :P
So a small ish update.  Had to figure a way to mount and hide the lcd casing.
« Last Edit: June 26, 2009, 09:26:34 pm by mj147 »
mj147
« Reply #19 on: June 26, 2009, 09:22:55 pm »
Used a rabbet bit (sp?)  so the monitor could be held and hide some of the bezel.  Dont laugh at my cuts its basically my first time using my router.
« Last Edit: June 26, 2009, 09:27:37 pm by mj147 »
mj147
« Reply #20 on: June 26, 2009, 09:23:55 pm »
Not the prettiest but it fit  ;D
mj147
« Reply #21 on: June 26, 2009, 09:25:45 pm »
The final result isn't too bad, least not for me. Still have to clean it up a bit and bevel the inside edge a bit.
mj147
johnmartin
  • Last login:April 19, 2010, 07:05:02 pm
    • My Fotki Photos
Re: My second Cab attempt, semi slim (update 6/26)
« Reply #22 on: June 27, 2009, 08:36:54 am »
Looks pretty good. I am surprised though that you did not make the hole a bit smaller to match the screen size a bit closer, but that is neither here nor there.  I like and and a bit of bevel will help a lot.
John
John M.
Fort Mill, SC
mj147
« Reply #23 on: July 01, 2009, 03:24:32 pm »
Well its been a few days and what johnmarttin said kept bugging me..why didnt I cut the monitor hole smaller.. :dizzy:
So I re did it since i knew it would bug me later as well.
mj147
mj147
« Reply #24 on: July 01, 2009, 03:28:40 pm »
I also cut out the speaker grill area. Gonna a try a mesh type material I stumbled across at the hardware dept at wally world.
Covered the back of the cab and will recycle the old monitor bezel so I wont have any heating  problems. This area will also be covered with the mesh, hopefully it will look decent.
mj147
mj147
« Reply #25 on: July 01, 2009, 03:33:04 pm »
Instead of painting Im gonna try to cover it with vinyl.  Wasnt too happy with the fist attempt as I had to peel off and re apply :angry: but that was my fault as I rushed it. Looks great from 6 inches or further.
My cab is 27" when it angles to cp area and the roll is 24" wide...I think I can make it work and not look too bad as the seem will be minimal.
Lemme know what you guys think so far.
  mj147
mj147
« Reply #26 on: July 01, 2009, 03:33:57 pm »
One more  8)
Gatsu
Re: My second Cab attempt, semi slim (upd 7/01)
« Reply #27 on: July 01, 2009, 03:37:34 pm »
that looks pretty good to me.
where did you get the vinyl by the way? I can never find any locally.
mj147
« Reply #28 on: July 01, 2009, 03:45:35 pm »
I ordered it through Amazon to save on shipping but its through Parts Express  24" X 18'
mj147
mj147
« Reply #29 on: July 01, 2009, 06:09:21 pm »
Ok a couple more  ;D
Figured Ill try the sides..... man it went on nice :P
Was very pleased with end results. Very small seam , more noticeable in pics tho.
mj147
mj147
« Reply #30 on: July 01, 2009, 06:10:12 pm »
mj147
« Reply #31 on: July 01, 2009, 06:11:27 pm »
Sorry for the spam but I can only fit one pic at a time. :dunno
mj147
mj147
« Reply #32 on: July 01, 2009, 06:12:09 pm »
Last one for today
mj147
mj147
« Reply #33 on: July 03, 2009, 04:05:31 pm »
Well still thinking of a way  to hinge the cp. For those who have used piano hinges, do you have to recess the hinge area so no gap is  visible?
Thinking I can can get away with just using 2 panel clamps to secure it. Will this be enough? My cp has a slight angle, almost horizontal and more than likely folks wont be hanging from the sticks.
mj147
« Reply #34 on: July 03, 2009, 07:08:14 pm »
Very nice.
I wouldn't do a piano hinge unless you want the hinge to be a visible part of the cab (in my case, that's what I wanted, but mine is FAR from a normal cab).
I'd go with one of those cup and socket cabinet hinges that have been mentioned on the boards here..
Well, I can't find the thread now, but here's the hinge i'm talking about.
http://www.rockler.com/product.cfm?page=21315&filter=hinge
mj147
« Reply #35 on: July 07, 2009, 08:50:53 pm »
OK got some more work in just a few more pics.
Added pictures of the new bezel, this time I managed to get the opening closer to the actual monitor screen.
I also cut a groove into the speaker panel so the plexi can be inserted and  held  by both the control panel and the groove.
mj147
mj147
« Reply #36 on: July 07, 2009, 08:52:10 pm »
Installed back vent grill  and did my first coat of paint on back of cab.
mj147
« Reply #37 on: July 07, 2009, 08:54:27 pm »
Installed the monitor,  used some blocks along with zip ties to hold it in place, just in case...
mj147
« Reply #38 on: July 07, 2009, 08:56:52 pm »
The plexi fit just fine.
Added some more T molding aswell.
Currently how she stands  ;D
mj147
jfh2112
  • Last login:November 27, 2010, 01:27:12 pm
Re: My second Cab attempt, semi slim (upd 7/07)
« Reply #39 on: July 12, 2009, 11:16:57 pm »
Wow, that's nice. I'm going to steal about six of your ideas for my slim cab.  ;D
How's the weight distribution? Does it seem top-heavy? I'd imagine not, with the LCD and all.
