Author Topic: billabs BL27CB0P  (Read 1289 times)
hohlraum
  • Last login:January 05, 2021, 08:40:55 am
    • Blog
billabs BL27CB0P
« on: June 21, 2009, 04:52:09 pm »
anyone have a custom inf that'll work with vista?  or how about a full powerstrip config for this monitor?  doesn't look like it has any plug and play info being sent to windows so with my nvidia gt8800 it shows all these resolutions and refreshes that aren't really supported.
Ummon
  • Trade Count: (+13)
Re: billabs BL27CB0P
« Reply #1 on: June 22, 2009, 05:43:56 pm »
It does seem to have some EDID, but yeah those res's come up as available. Stay away from them and you won't have an issue. Even then, all it'll do is shut down. If you happened to switch res (or refresh) that is out of specs from within the card software, Windows'll give you a little 'you have fifteen seconds' box, and then it'll switch back. If you accidentally do it from from Quickres, well, then you'll have to hook up another monitor and switch back manually.
Yo. Chocolate.
Stephen Hawking
