Author Topic: Some games don't work on MAMEUI32 0.132u1  (Read 10262 times)
Gavica
  • Last login:March 05, 2011, 09:56:15 am
« on: June 21, 2009, 04:20:08 am »
Until recently I was using MAMEUI32 0.122u1
this quite an old version like from 2 years ago.
So I download the newest version and copy the roms over, but several games are not working, for example 1941, 1942, Punisher, and many other say:
buf1 not found
ioa1 not found
prg2 not found
rom1 not found
but they work perfectly fine on the old MAMEUI32.
Anyone knows what could be the problem?
mr_doles
  • Last login:November 25, 2025, 08:42:10 am
  • nuff said
Re: Some games don't work on MAMEUI32 0.132u1
« Reply #1 on: June 21, 2009, 08:20:38 am »
I use mame and not mameui so I could be way off base with this answer but you may have to get newer versions of the rom.  Looking at Maws I see that:
1941 - Counter Attack (World) - last change(s) .126u5
1942 (Revision B) - last change(s) .124u5 .124u4
1942 (Revision A) - last change(s) .124u4
The Punisher (World 930422) - last change(s) .127 .126u5
etc...
Just a thought.
Robbbert
  • Last login:Yesterday at 03:19:56 pm
« Reply #2 on: June 21, 2009, 11:40:17 pm »
Those appear to be cps1 games, recently a bunch of proms was added to each game, even though they are not used internally. You will need to update your collection.
dmckean
« Reply #3 on: June 22, 2009, 01:54:55 am »
Every time you upgrade MAME you need to upgrade the ROMs also.
Gavica
« Reply #4 on: June 22, 2009, 02:55:48 pm »
I upgraded the roms and all is working perfect now, thanks guys
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #5 on: June 22, 2009, 03:36:45 pm »
That's an exaggeration.  More like "Every time you upgrade MAME you also need to check and see if any of the romsets you use were also upgraded."
Only about 1% of the romsets change between major versions.  Also, a single game might be updated multiple times over multiple mame versions; IOW, if a romset changed recently, it has a higher chance of changing in the near future (because it's being actively worked on).  This also means that if you jump, say, 10 versions of mame, you'll probably have less than 10% of the romsets need to be changed.  (I'm talking generally, with rounding, so don't use these these as hard fact, always true, numbers; but they're okay guidelines.)
Robin
Knowledge is Power
jholman76
« Reply #6 on: June 22, 2009, 05:27:21 pm »
I'm looking to move from .124u2 to .132u1. Is there a way to see what I need to update besides looking at 124>125....125>126....126>127....  etc?
I noticed a lot work, but some of my favs (SF2CE) is not showing up.
Thanks.
Robbbert
« Reply #7 on: June 23, 2009, 05:03:48 am »
sf2ce is also a cps1, so you need to upgrade your roms.
mr_doles
« Reply #8 on: June 23, 2009, 10:21:38 am »
That info is in mame.dat is it not?  I wonder if there is an app that can pull that info out to show you what has been updated since version x.  Will romlister do that?
jholman76
« Reply #9 on: June 23, 2009, 11:14:06 am »
I'm not going to worry about it.. just going to update to the .132 romset. Its enough work just to sort through the roms I even want. Too bad there isnt an app that can read my mind and delete the games I dont want!
joe
mr_doles
« Reply #10 on: June 28, 2009, 09:40:40 am »
Does anyone know if any of the Rom managers out there will this now?
I agree with that but the problem is not if you have to update 2 games or 50 games, its the fact that you have to check all your games each time.
Nemss316
  • Last login:April 28, 2010, 10:30:00 am
« Reply #11 on: July 01, 2009, 05:37:30 pm »
Sorry, but a nOOB question, but upgrading ROMS, you mean downloading the games again, and installing them into the newest verison of MAME? Or is there a way to actually pick the rom, and update it to the newest version?
mr_doles
« Reply #12 on: July 02, 2009, 09:21:25 am »
You need to get the newer updated version of the ROM.  Can't say where to get them though, against forum rules.  ;D
Nemss316
« Reply #13 on: July 03, 2009, 10:57:45 am »
That's all I needed to know!  :cheers:
Ummon
  • Trade Count: (+13)
« Reply #14 on: July 05, 2009, 04:10:41 pm »
Early on, there were a few attempts to enable auto-updating of roms. Arcade@home (now long defunct) was one of them. Perhaps in another several years.
Yo. Chocolate.
Stephen Hawking
