Author Topic: mortal kombat pcb  (Read 1206 times)
xrodney
  • Last login:August 31, 2023, 09:57:19 am
mortal kombat pcb
« on: June 20, 2009, 03:35:31 pm »
hi, i was reading the manual and it says that that the cabinet must have -5v.  some says that -5v can damage an mk1 pcb.  which one is true?
i have a 2 in 1 jamma switcher and the picture when 1 switch to the second connector is not good. when there is the ro check the picture seems smudged and there are like shadows in the game, can it be from the pcb?
MonMotha
Re: mortal kombat pcb
« Reply #1 on: June 20, 2009, 05:56:29 pm »
Almost all Midway boards require the -5V line hooked up.  They use it over in the audio processing area.  MK1 should be like this (I believe it uses the same sound board as NBA Jam which definitely uses the -5V line).  No game complying with the JAMMA spec should be damaged if -5V is hooked up in the proper location, though many don't use it.
