Author Topic: How easily swappable are Pacman/Defender control panels?  (Read 6044 times)
GaryMcT
  • Last login:September 24, 2014, 11:19:27 am
    • GaryMcT's arcade blog
« on: June 19, 2009, 10:06:31 pm »
I'm contemplating buying a Pacman machine for vertical Mame and a Defender machine for horizontal Mame.  I can get replacement control panels here for both:
http://www.arcadeshop.com/cabinets/cabinets.htm
Have any of you built multiple control schemes this way and made it easily swappable via a connector?  How did it turn out if so?
My blog on learning how to develop FPGA versions of arcade boards: http://garymct.blogspot.com
daywane
  • GRRRR!
Re: How easily swappable are Pacman/Defender control panels?
« Reply #1 on: June 20, 2009, 07:33:36 pm »
only thing like that I did was Pac Man , Ms Pac, Super Pac CP swapable
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« Reply #2 on: June 20, 2009, 09:02:09 pm »
If making a modular or swappable panel, just using interfaces that have a USB connection should be sufficient as you just unplug the cable from the interface mounted on the panel and plug it into the interface on the swapped panel.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #3 on: June 21, 2009, 09:00:40 am »
I didn't know that Steve stocks Defender panels (and even after checking don't see any).
Working: Not Enough
Projects: Too Many
Progress: None
daywane
  • GRRRR!
« Reply #4 on: June 21, 2009, 02:50:02 pm »
I have the GPWiz wired to a 25 pin femal port.
CPs are wired to 25 pin male port.
Radio Shack
GaryMcT
« Reply #5 on: June 21, 2009, 03:53:51 pm »
you are right.  Doesn't look like he has defender layout control panels, but he does sell early Williams-style machines. If he sells tha control panels separately, especially blanks, that would work for me
CheffoJeffo
« Reply #6 on: June 21, 2009, 04:27:59 pm »
While I don't have a Defender in the house now, I'm pretty sure that the panels from Joust/Robotron/Stargate won't fit a Defender cab ... which is why he sells overlays in two sizes -- one for Joust/Robotron and one for Defender.
Working: Not Enough
Projects: Too Many
Progress: None
GaryMcT
« Reply #7 on: June 21, 2009, 10:25:38 pm »
Doh!  I emailed him to be sure.
Worst case, I have to make them myself I 'spose.
GaryMcT
« Reply #8 on: June 25, 2009, 03:35:11 pm »
You are absolutely correct! :)
Thanks for the info.  Turns out that making a Defender control panel is far easier than I had imagined. :)
mytymaus007
« Reply #9 on: October 23, 2009, 07:22:49 am »
whats the latest on your control panel journey would like to see if you built anything yet
TOK
  • Last login:Today at 08:47:34 am
  • The Game Always Wins
« Reply #10 on: October 23, 2009, 07:34:31 am »
You mean having a separate keyboard encoder for each panel? That'd get spendy.
I think it would be better to have the encoder stay with the cabinet and have all inputs wired to a connector that connects it to the panel. I think people have used printer cables for this in the past.
I considered swappable panels when I did my first machine, but then decided I would rather have multiple games... I ended up with a horizontal a vertical and one with a dedicated Stargate layout that will also work for Defender and a bunch of other 1 or 2 button games.
bkenobi
« Reply #11 on: October 23, 2009, 04:47:42 pm »
So instead of spending an extra $20-40 on an extra encoder, you chose to spend a few hundred on more cabinets (including extra encoders)?  My wife would have seen right through that logic!   :laugh2:
GaryMcT
« Reply #12 on: October 23, 2009, 04:53:20 pm »
It's still in the prototyping phase.  I keep building new versions and moving stuff around.  I think I'm pretty close though now so that I can start thinking about getting some art on there and building a final one.  I'll try to remember to put a picture up soon of where it's at.
CheffoJeffo
« Reply #13 on: October 23, 2009, 04:55:43 pm »
So apparently you aren't the Jedi that you would have us believe that you are ...
Working: Not Enough
Projects: Too Many
Progress: None
TOK
« Reply #14 on: October 23, 2009, 07:23:01 pm »
I used to bring motorcycles in the house. She considers this great.
Ya gotta break 'em in right.  ;)
