Author Topic: Radius and T Molding  (Read 3967 times)
Fitznab
  • Last login:July 27, 2009, 10:18:29 pm
« on: June 18, 2009, 06:09:33 pm »
Hello all,
Is there a minimum radius that t molding will bend with out issue?  Visually my curve looks fine but I want to make sure its big enough before I cut.
severdhed
  • Last login:Today at 07:32:51 pm
  • RIP Dinosaur Hippo
Re: Radius and T Molding
« Reply #1 on: June 18, 2009, 06:44:29 pm »
you can do some pretty tight turns with t-molding...you just need to notch the spline so that it goes in properly.(cut little "V" shaped chunks out of the spline where the curve is)
Haterot
  • Last login:November 09, 2012, 09:27:41 am
« Reply #2 on: June 19, 2009, 12:46:11 pm »
You can also take the spline out completely. I wouldn't take out a lot (i.e. 3 inches) but with a curve or a bend you can take the spline out and as long as you have enough tension on both sides it will hold and if it doesn't or droops, I would run a small bead of hot glue to hold it once you got it molded right.
Empire had the better ending. I mean, Luke gets his hand cut off, finds out Vader's his father, Han gets frozen and taken away by Boba Fett. It ends on such a down note. I mean, that's what life is, a series of down endings. All Jedi had was a bunch of Muppets
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #3 on: June 19, 2009, 01:55:13 pm »
I tend to cut out chunks so im left with wedges, but for really sharp corners, yeah, cut the whole thing off, except maybe some small protrusions
NO MORE!!
NoOne=NBA=
« Reply #4 on: June 28, 2009, 05:03:31 am »
The big problem is going the other way.
With an inside radius, there's nothing to hold the t-molding in.
That's where finishing nails come in.
A few carefully placed nails through the side of the cabinet, and into the t-molding work perfectly.
RayB
  • There's my post
    • RayB.com
« Reply #5 on: June 28, 2009, 02:52:07 pm »
No no no... cut pie wedge shapes. Or even rectangle protrusions are good enough to hold it. Don't cut it all off on inside curves.
NO MORE!!
