Author Topic: Emumovies previews don't display centered  (Read 2065 times)
cabecita
  • Last login:January 16, 2012, 11:06:21 am
« on: June 18, 2009, 06:51:19 am »
Hello,
I have installed a layout with the video previews "Emumovies SQ", and it don't display centered. What's happening?
system01
  • Last login:March 04, 2023, 08:06:55 pm
  • System Idle Processes are the Devil's Playthings
Re: Emumovies previews don't display centered
« Reply #1 on: June 19, 2009, 09:57:19 pm »
You're gonna have to give more info.
You mean in the 'video' box you set up in MalaLayout?
Centered on the screen?
Looks centered in MalaLayout but not when you are in the FE?
Used "don't" when you should have used "doesn't"?
Is this a downloaded layout?  Which one?
Henrik68000
  • Last login:December 12, 2010, 01:54:23 pm
« Reply #2 on: June 22, 2009, 12:23:29 pm »
you will need to open the layout editor and center and size the movie frame. (if the case is that you downloaded a layout made by someone else).
