Author Topic: critter crusher how to start?  (Read 1262 times)
mimic
  • Last login:July 20, 2025, 09:41:28 am
« on: June 14, 2009, 11:52:19 pm »
Anyone knows how to start this game? Mame32 ver0.132 Start doesn't work nor any button. And there is message on the screen that cartridge is not properly inserted, except cartridge is in digital version now, so it should fit just fine  :P
severdhed
  • RIP Dinosaur Hippo
Re: critter crusher how to start?
« Reply #1 on: June 15, 2009, 12:43:24 pm »
according to MAWS...
SETUP:
    * After 'ERROR ON CARTRIDGE' press SERVICE (Key 9) and then TEST (F2) to get into the ST-V TEST MENU. Select 'SYSTEM ASSIGNMENTS' with SERVICE and press TEST to proceed, then set 'CABINET TYPE' to 1P (one player) and EXIT the test menu.
« Last Edit: June 15, 2009, 12:46:06 pm by severdhed »
mimic
« Reply #2 on: June 16, 2009, 12:11:14 am »
Thx a lot, I was looking into service settings, but didn't find anything special there, didn't know there is some kind of step by step required.
severdhed
« Reply #3 on: June 17, 2009, 09:09:02 pm »
you're welcome. i have only run across a few games that require special steps to get them running like that...if you run across problems like that with other games, check maws...it will usually list the steps to get it working
